Question about GE 29875GE Digital Answering Machine
Machine Model 29875 plays a 3 note melody for no apparent reason. Sounds like the first 3 notes of old song called "Bless 'Em All", of WW2 era. Does this several times per hour. Any help?
Bless the lord o my soul by matt Reman
This is a great song and my band plays it..Its actually called 10,000 Reasons .you are asking for the chords??? I play it like this...
10000 Reasons Bless The Lord Chords Good luck
Feb 26, 2015 | Word Music Music
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
An old song(1930s)"a pretty girl is like a melody"
"A Pretty Girl Is Like A Melody" is a popular song written by Irving Berlin in 1919 which became the theme song of the Ziegfeld Follies. The first verse and refrain are considered part of the Great American Songbook and are often covered as a jazz standard.
Wikipedia: Pretty Girl Is Like Melody
Recording:
pretty girl is like melody
Feb 23, 2015 | Miscellaneous
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Sep 02, 2014 | Seiko Melodies in Motion Clock
My platinum videoke player with model T40 is not working the audio signal output. is is requesting password
Platinum T40 Player problem
- MTV, MP3, DVD Movie, MIDI Introduction it works
- I played (RS) True Instrumental Songs, but need to set a Melody Off to remove bad sound and need to set Signer ON. If Singer OFF no sound output.
- Sound perfect Songs
- Evolution Songs
-Chorus Songs are played, video and lyric is ok, but sound like a laser gun and sound wave sometimes like a storm and cheer song is bad sound.
please help me...
what is the best thing to do...
Jul 30, 2011 | Audio Players & Recorders
I have a casio lk-44. I want to be able to play a song from the songbank, but just hear the background rhythm and not the melodies. I want to play the melody myself from the songbank. When I pick a song...
Not sure if your "booklet" is the full user manual... if not go to this site and go through their "hoops" and download the full user manual. It shows how to put the unit in the mode that merely lights the keys and plays the rhythm, unlike the "demo" mode.
http://www.retrevo.com/support/Casio-LK-100-Music-Keyboards-manual/id/467dj395/t/2/
Note the manual is free via the Retrevo site... just have some of those annoying hoopps like email address and entering numbers.
Mar 21, 2011 | Casio LK100 Lighted Keyboard With LCD...
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Hello, i have a problem whith the bear, when I play a song, it sounds correctly, but when there have been played 10 seconds of the song the bear is turned off automaticaly.I dont know if its a fail
Lulla-Bear is shipped in Battery Saver mode. There are two possible solutions to the problem you note, depening on the model you have. Please check the battery pack. If there is a plastic tab, remove it. Also, make sure the "On/Off" button is turned to the "On" position. If these actions do not correct the problem, please contact CrowleyJones info@crowleyjones.com or call us 512-426-2146 and we will provide you a new Lulla-Bear.
Dec 23, 2010 | Bear Lulla "Brownie"
I'm trying to use a new program called Fruityloops 8 XXL edition, and I cannot figure out how to take sounds from different channels and put them on a playlist in order to tweak different tracks or play...
i have fl9 xxl producers edition, check me out www.reverbnation.com/timcpatc,
first, next to the play stop buttons is a "pat" and "song".
click song, if you look right of tempo it has number 1, <take notice. now you click the very left button in this pic, (the playlist) find the line with number one and left click so it looks like thisb122beb.jpg
exit the playlist and right click on the instrument u wanto use, click send to piano roll, thats where you put your notes,.make a tune or drum loop.this will go into the playlist number 1 chanel. go to the number one o the right of the tempo, (it has pat under it) an chang it to 2, open playlist, put a block like you did in pattern , right click the instro u want to use, send to piano roll, make ya tune, this will go into playlist number 2 chanel, in the playlist place them where you want them by the way. every time you go to piano roll and put a tune or something in that instrument will link to the pattern number and the pattern number links t the playlist. left click on the little oval ligh light next your instrument and make them all light up green,when u have done that go to to the icon next to playlist an choose view mixer, and right click on the Chanel next to master (insert 1),link to selected channels,click starting from...
now on the very right click of mixer where ther is numbers, click the arrow so a dropdown menu appears, pick your effect. (highlight what instrument you want to add an effect to in the mixer.) generaly not for master unless the effectss are compressoors soungoodizers and eqs and stuff, ( mastering tools) HOPE THIS HELPED
Dec 14, 2009 | Image Line FL Studio 8 XXL Full Version ...
GE 29875GE Digital Answering Machine Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
