Question about Alienware PC Systems Computers & Internet
What reasons would you go into the BIOS? - Alienware PC Systems Computers & Internet
How are the default bios settings for a desktop hp pentuim 4 computer. The main reason why I' asking this is that I'
ok you reset your bios by given process
Yet another way to clear the CMOS is to reseat the CMOS battery. By removing and then reinstalling the CMOS battery, you remove the source of power that saves your computer's BIOS settings.
Another way to clear the CMOS is to short the "CLEAR CMOS" jumper on your motherboard, assuming you have one (most motherboards do).
May 18, 2012 | Computers & Internet
Reason for showing "check main
your bios has been damaged the bios chip on your motherboard could be damaged to check it
restart your compuetr during the boot up process you will see a certain key to press to enter set up (bios) press and hold that key to enter bios using the arrow keys scroll to load optimised defaults
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date.
Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Save, Exit and re-boot and everything should then work.
hope this helps you
Sep 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
I neeb bios update for sahara laptop al096
Don't do it unless there is a VERY COMPELLING REASON. BIOS flash upgrades don't always go well. If it fails for ANY reason, you are out of business ... rarely can you go back with success.
This is a case of if it ain't broke - don't fix it.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Computers & Internet
I have dell inspiron 1545 bios password and don't know what to do!
I use http://www.unlockbiosrecovery.com/Unlock_Dell_Bios.php to get the bios master password that clears the current bios password. You then have full access to the bios setup. I have use them many times with no problems. I come across a lot of Dell laptops that have their bios password set for no reason. I think there may be a bug in the bios that causes it to set bios password.
Sep 05, 2011 | 1995 Buick Regal
Resetting bios for a a135-s2266 lap top aclues? ronb1567@live.com
You can reset the BIOS by pressing the F9 key in the BIOS window. May I know the reason for resetting the BIOS? Please elaborate the issue in detail so that I can provide the clear resolution
Jul 04, 2010 | Toshiba Satellite A135-S2266 Notebook
Can't access BIOS setup due to keyboard-less operation being on
My friend, excuse the little smile I have on my face.
You are in a pickle. If I found myself in this situation, I would open the computer, find the BIOS battery and remove it. Wait 5 minutes and reinstall it. This should restore the manufacturer default values for your computer
In the big picture, there is little reason for anyone to enter the BIOS and make changes ... and for good reason. Dont do it unless ther is exceptional reason to do so.
Thank you for your interest in FixYa.com
please vote
thanks
a
Dec 20, 2009 | IBM ThinkCentre S50 PC Desktop
Asus bios problem
Unless there is a compelling reason to update the bios it should be left alone. Apparently this is one reason for that sage advice.
Go back to asus, download an older version of the bios and install it. Fortunately you didn't end up unable to boot or you would be buying a new board.
Apr 29, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
My toshiba satelitte has for some reason has started to ask for a bios password. How can I reset ir?
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
Toshiba's backdoor password is TOSHIBA
Jan 04, 2009 | Computers & Internet
I have bought a new pc this one and has vista
the reason is the bios, when these pc's are built they are built to run Vista and the bios version is refering to vista and not XP, you will need to download and install an earlier version if this is possible, install XP then instal vista on a seperate partition if you require it.
Oct 20, 2007 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Frank Zabroski
Frank Zabroski
Larry Chandler
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
