Question about Electronics - Others
Maxim mx11-26 won't power up
When wired up no power light comes on fuse in plug changed still nothing works
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: tv went off an no power no power light changed plugs still nothin
Although it deals with a different brand and model, the diagnosis is the same and you can try what is suggested in my reply here:
Dead set
Posted on Mar 22, 2009
  • 330 Answers
SOURCE: left bike run bike shut off then could not get no
check the fuse on the start relay (30 amp i think)
Posted on Apr 30, 2010
caarsinc
  • 82 Answers
SOURCE: my asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Posted on Dec 15, 2012
gopakumarg43
  • 74459 Answers
SOURCE: no power.
Check and replace the main power supply regulator board as card basis. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 21, 2014
I replaced the ignition lock cylinder in my 92 cabriolet and I turned the key and it started first swing, then I was putting the steering wheel covers back on and it just turned off... When I try to turn...
If it's an automatic check fuse #15 wether it's a stick or automatic you should have power at the red & black wire coming out of your ignition switch when you turn key to start postion and power at the red wire going into switch at all times. if no power coming oit on the red/black wire you need an ignition switch. if there is power coming out of switch try putting car in nuetral (for auto trans). if still nothing you'll need to check for power at small wire going to starter when key is turned to start. if has power then need starter if no power you'll need to check starter interlock relay.
Dec 31, 2012 | Cars & Trucks
1982 400 Maxim no lights or anything will come on could this be the solenoid?
Hi, Aaron before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
400 maxim won crank
totalmotorcycle com
Yamaha XS360 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
May 09, 2012 | Yamaha Motorcycles
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Brake lights on my 1999 dodge Durango won't come on. I have all ready change all the fuses, the brake switch and even all the light bulbs and they still won't come on
Hi, is there power getting to your brake switch? I have pasted the diagram below. If there is power to the brake switch, the problem is the wiring. If no power to the brake switch, it may be the fuse or the wire from the fuse to the switch.
Oct 17, 2011 | 1999 Dodge Durango
The unit won't come on. I pushed the reset button but still nothing. The green light on the plug its self comes on but nothing on the air conditioner comes on.
There might be something wrong with the wiring connection. Check for open wire, burn-out wire or worn-out terminal lug from your control box. Unplug the unit and unscrew the control box to find the problem.If you found nothing abnormal plug it in and test with volt meter if power is coming at the end of the wires (connected to the plug). If no power at the end of the wires, it is broken near the plug. Cut the wire and reconnect it back to a new plug.
Sep 01, 2011 | Crosley Heating & Cooling
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
Headlight and meter lights
this problem can be solved by checking the wiring of the bike, all you need to do, with the help of the multimeter turn on the bike and light and check with the multi meter, are you getting the power, else you need to the change the wiring,, this will surely solve your problem,, thank u,, plz rate me,,,,
Jun 01, 2009 | 1985 Yamaha XJ 700 S Maxim
Maxim 32'' monitor style tft lcd tv
Maybe your tv has a busted fuse replace it same value. if a new fuse busted again it means your tv has trouble maybe in primary or secondary power.
Apr 10, 2008 | Televison & Video
Electronics - Others Logo
49 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
