Question about Ingersoll Rand Rotary Screw Compressor 230 Volts Single Phase 5 HP 185 CFM
Ingersoll rand sm 110 m high intercooler pressure problem. what ould be the cause if the pressure sensor is ok.
Compressor switches on and stops 2 seconds latter and displays HIGH INTERCOOLER PRESSURE
3 Suggested Answers
compman66
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
compman66
  • 169 Answers
SOURCE: Ingersoll Rand Air compressor loosing pressure
sounds like you have a problem with the discharge valve on the secondary cylinder, some I.R. pumps rely on the cylinder head valves to hold back tank pressure when the pump comes to a stop. the line down to the crankcase in front of the crank is a unloader valve that dumps the air pressure inside the pump to allow the next restart. I think that once you drain the tank and remove that cylinder head you will find a defective valve in the head.
Posted on Mar 26, 2010
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
I have old Ingersoll Rand compressor type 30 model 15T serial # 243496 Blow fuss when restart ?
Probably a faulty non return check valve, when the unit reaches pressure air in the delivery pipe is vented down at the pressure switch. If the check valve is passing back this will cause the unit to try to start against a pressure causing it to pull high amps and trip. If there is a constant hiss coming from the pressure switch when the unit stops it will be the non return valve. There should be a short hiss of air when units stops If there is no hiss at all when the unit stops it could be a faulty pressure switch. If it is a quick fix would be to create a small leak on the delivery pipe to vent the line down.
May 28, 2014 | Ingersoll Rand - Rand Type - 30...
High intercooler pressure
1 st you'll have to detrimine if this is a sensor fault or a real pressure problem , disasemble intercooler to ck for blockage
May 20, 2014 | Ingersoll Rand Tools & Hardware - Others
Please help!! my IRN55K-OF-N55 alarm "high intecooler press"
well a quick sub out of sensor in intercooler with a pressure gauge is a easy way to see if its a sensor failure or a intercooler blockage , i do believe that hole is tapped 1/8 npt pipe thread so a gauge screws on real easy
Apr 07, 2014 | Ingersoll Rand IRN7H-115 Nirvana...
Please help!!! my IRN55K-OF-N55 alarm "high intercooler press"
Your problem is valve discharge closed, so the pressure cannot out from inter cooler.
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
The compressor starts and stops after a short time, and displays Low unload sump on the ingersoll rand air compressor.
Mar 07, 2010 | Ingersoll Rand Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand Rotary Screw Compressor  230 Volts Single Phase 5 HP 185 CFM Logo
47 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
