Question about Miele W864 Front Load Washer
Flashing rinse light on meile 864 and anti crease/ finish light comes on.
I have changed the brushes in the motor but still the same fault. The drum will not move in any program. any suggestions please?
    New Friend:
  • 24 Answers
If you are sure that you made no mistake in mounting the brush cap back on the motor (check the four pins), most probably the electronic EL200 is defective.
This happens often in this type of machine when the shock absorbers are worn (after 10 years).
You can check this by measuring the continuity in the little 6.3A fuse that is on the EL200. If it is blown, you may get the PCB repaired for 55 Euros + shipping (see link below). You also have to replace the shock absorbers (32 Euros) to get a full year guarantee.
Miele Reparatie EL200
Posted on Feb 17, 2014
3 Suggested Answers
SOURCE: machine wont programme
I hate my meile washer
Posted on Jul 12, 2008
SOURCE: Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
Posted on Sep 12, 2009
How do I reset the flashing rinse light on a bosch wae24060gb following a motor brushes change ? thanks.
Turn knob to 12 o'clock position turn to 6 o'clock position press an hold the spin button turn knob to 7 o'clock while still pressing the spin button let go of the spin button after 5 seconds turn the knob back to 12 o'clock
Dec 10, 2014 | Bosch Washing Machines
I have a bosch classixx tumble drier, condensing type. When I try turning it on, select levei of dry. Then press the start button I get a bleep, then the 'drying light', 'iron dry light' & 'anti-crease/end...
Sounds as though you need to unplug then empty the water from the water container & the lint box, then definitely open the bottom flap & by rinsing & drying the condenser box gently to avoid damage use an old tooth brush, once all these are complete plug back in & try again, as it will not reset until all these are empty & clear, hope this helps.....
Jan 24, 2018 | Washing Machines
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
May 10, 2009 | Miele Novotronic W1918A Front Load Washer
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele W864 Front Load Washer Logo
331 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
