Question about Casio M140 Dlp Projector Laser/led Mpn: Xj-m140
White dots on Casio LED projector screen
White dots appear on screen
My Sanyo PDG_DX100 projector only 100 hours now, its started white dots and balck dots how to fix it. if DMD chip problem, how much it cost me.
Sanyo PDG DXL100 1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200 We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Jul 23, 2014 | Sanyo Office Equipment & Supplies
How do i get rid of white dots?
This is a dlp projector and has a bad DMD chip. Most models are very similar. Here is a video of a similar repair.
Feb 07, 2014 | Mitsubishi XD250U-ST DLP Projector
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
Jerry
Lampdeng Limited
Jan 27, 2014 | NEC Lamp for NP215 Projector
Mitsubishi xd280u white dots
bad dmd chip $200 http://www.youtube.com/watch?v=775YOs-aOPc&feature=share&list=UU_Iacxxa-E63l6FhQjkcH8A
Jan 20, 2013 | Mitsubishi XD280U Projector
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
White dots appears in my screen. I replace the lamp and the problem is the same. (Sharp xr32x)
I would be willing to bet the DMD chip is failing the cheapest used one i seen was on e-bay the chip # will be something like 1076-6319W the only part of the # that matters is the last from what i have seen they tell me the 6318W and 6319W is suppose to be the same chip the used on i seen on e-bay was $124.00 probably better off seeking a new projector if you can not replace yourself as you will have over half of the cost involved hope this helps Robert
Aug 29, 2012 | Sharp "XR-32X-L DLP Projector"
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.
Are they stationary and always in the same position? You may have bad pixels.
Are the dots there with no signal going to the projector?
What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?
It is probably your projector.
If some of your sources are fine - the problem might be from a connected source.
Hope this helps.
Aug 26, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Many white dots appears on the screen of my benq w600 projector
Jacob, what element on the mainboard is the source of these dots? I have the same problem - it is only one dot now, but I think there will be more with time.
Also, the second question is: how do I unscrew the mainboard from benq W600+? I remoced the metal cover, unplugged all the cables, but there's something still not letting the board go.
Jan 29, 2012 | Office Equipment & Supplies
Dots appearing on the display screen
if these are pixel shaped dots then the DMD chip is most likely faulty
Apr 11, 2011 | BenQ MP622 DLP Projector XGA 2000:1...
InFocus
Hi there
That is a definate Mainboard replacement.
Must warn you that it could turn out to be a expensive exercise
Feb 06, 2008 | InFocus ScreenPlay 4805 Multimedia...
Casio M140 Dlp Projector Laser/led Mpn: Xj-m140 Logo
60 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
