Bryant Plus 90 furnace
My friend has a Bryant plus 90 furnace. it starts up fine, ignites, blower runs, but the air its blowing is not warm at all. they can only get their house up to about 62 degrees. it does not have any error codes. intake and exhaust pipes checked outside. no blockage. any suggestions?
  • 148 Answers
Possible your supply duct leak or break
Posted on Feb 14, 2014
2 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Bryant Plus 90 Furnace - Blower works fine and
PRSSURE, DRAFT SAFGUARD, AUX-LIMIT SWITCH(WHEN USED)OR BLOCKED VENT
SWITCH(WHEN USED) DID NOT CLOSE OR REOPENED (DOWNFLOWONLY)
If open longer than five minutes, inducer shuts off for 15 minutes
before retry.
Check for:
* proper vent sizing
* defective inducer motor
* restricted vent
* excessive wind
* low inducer voltage(115VAC)
* defective blower motor or capacitor
* defective pressure switch
* inadequate combusstion air supply
* disconnected or obstructed pressure tubing
If it opens after trial for ignition period, blower will come on for
90 sec. recycle delay.
Check your air filter for blockage, check pressure switch for a buildup of moisture. Make sure your inducer motor is turning and creating a vacuum to the pressure switch. Make sure all venting is clear and free of water or debris. Make sure there is no water in inducer motor and all drains are draining.
Posted on Jan 28, 2010
Bryant i90 plus wont blow warm air. Blows runs noemal but not warm air.
NOT 100 % FAMILIAR W BRYANT BUT IN GENERAL HEATER CONTROL VALVE IS GENERAL CAUSE OR LOW ENGINE COOLANT
Feb 14, 2016 | Cars & Trucks
I have a bryant gas furnace plus 90 the furnace kicks on and the pilot lights but the fan that blows the heat thru the house wont turn on! I keep getting error code 44 and 41 what can i do to fix that?
make sure fan wheel turns freely
check for voltage to fan--if you have voltage check capacitor output against capacitor rating, must be withing 5%, if that checks out replace blower motor
Jan 17, 2014 | Heating & Cooling
Light pilot reset
If yours is a high-efficiency furnace, you should hear the stack blower start running when your thermostat calls for heat. Next, the igniter should start to glow and remain glowing until the thermocouple opens the gas valve and allows gas to flow to the main burner. The main burner lights and burns until sufficient heat is generated for the main blower to turn on and blow warm air through your house. If any action does not occur in the order described, repairs are in order.
Dec 08, 2013 | Kitchen Appliances - Others
Ruud 80 plus furnace
Make sure you give it time. Gas furnaces ignite first and then the fan comes on. It will run for a while to heat the exchanger first. If the fan comes on with the heat it will blow cold initially. The fan also continues to run after the burners shut off to expel the existing heat in the ductwork
Oct 19, 2013 | Heating & Cooling
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
I have a bryant 90 i and when it calls for heat the inducer doesnt even come on
The first thing I would do is to verify that you have power to furnace. Check breakers and there may be a swith with a fuse in it mounted to side of your furnace or close by check fuse. You can use volt meter or test light to check for power. After you're sure you have power and thermostat is calling for heat if draft motor does not start you need to replace it. Draft motor is the first step in furnace start up.It should run for 30-45 seconds.then spark igniter or hot surface igniter should light pilot. It should stay on for about 20 seconds then burner should light. After burner lights the main blower should come on in about 2 mins. If you can get draft motor to run then procede to next step. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Bryant Plus 90 Furnace - Blower works fine and intermittently blows warm air but will not bring house to temp set on thermostat... Get a 1-3 error (one blink and then 3 quick blinks of the LED) Thanks
before retry.
Check for:
* restricted vent
* excessive wind
Jan 28, 2010 | Heating & Cooling
Heating & Cooling Logo
322 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
