Question about KitchenAid Dishwashers
Dishwasher wont start, add a dish light blinking
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
SOURCE: kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Posted on Jan 10, 2009
SOURCE: The start light just blinks and the dishwasher wont start?
just found a web site that says crack door open, press normal, hot dry, normal, hot dry, then cancel to reset the controls.
Posted on Mar 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: My dishwasher clean light is blinking 7 times & not clean
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 22, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
MY KITCHENAID DISHWASHER FAILS TO POWER OFF
Programmer fault.......time for repair man or replace machine. I assume out of warranty.
Jul 21, 2014 | KitchenAid 24 in. Built-In Superba Series...
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
I have the Whirlpool Quiet Partner 1 the wash cycle starts and about 20 Min.'s into it the clean light starts flashing or the the start light, one or the other each time and it wont dry the dish's anymore...
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
Jan 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
60 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
