Question about Samsung LN40A530 40 in. LCD TV
I have a Samsung UN46ES6150FXZA. It will not power up. I get 2blinks followed by short quick blink and then it repeats itself
2 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: I have a Samsung LN40A530P1FXZA. It will not power up. I get 2blinks followed by short quick blink and then it repeats itself. I have replaced the power supply board and also the main board, and it s
try to download the manual on www.retrevo.com to see the error code for sure..
Before you decided to replace t-con board please refer to the manual first,,but there is the possibility that t-con was faulty.
Hope it helps..don't forget to rate..
Posted on Jul 19, 2012
Samsung TV model UN46ES6150FXZA, had sound but no picture, use flash light can see the picture, so no back light. Should I replace the power board of it? Or is there other part to control light?
Yes replace the power board, or just replace the capacitors on the power board. If they look swollen, then they need to be replaced. Very common on Samsungs.
Sep 07, 2017 | Samsung Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
I have a Samsung LN40A530P1FXZA. It will not power up. I get 2blinks followed by short quick blink and then it repeats itself. I have replaced the power supply board and also the main board, and it still...
Jul 18, 2012 | Samsung LN40A530 40 in. LCD TV
My Mitsubishi TV power light comes for about 12 seconds, without any picture, and turns off.
Try the self check when power light goes off, on front press and hold both the menu and input buttons for at least 5 seconds and let both go.
Power light will blink a two digit error code like 2 blinks,2blinks, pause and repeat it several times.
What error code do you find?
SD TECH
Oct 18, 2011 | Mitsubishi VS-55609 55" Rear Projection...
Power comes on but goes rite back off
Hello.
you can try to retrieve error code first.
Plug TV into wall outlet. Push power button, let it do whatever it does. After that push BOTH buttons in front of TV named "Menu" and "Input" and hold it for at least 5-6 seconds.
Green LED in front of TV will start blinking error code (when it starts you can let buttons go).
If it clinks like "2 blinks, pause, 2blinks longer pause, repeat" most likely you have convergence issue. Two convergence amps have to be replaced along with couple PICO fuses that already open.
I would strongly recommend to let professional do this repair. As well in case of different error code.
Should cost you in ball park of $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Turns itself off after being turned on.
Here is what you do:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
LET me know what you find and I will tell you what it means and if possible how to fix it.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 07, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Sep 17, 2007 | Toshiba Satellite A55-S1066 Notebook
Samsung LN40A530 40 in. LCD TV Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
