Question about Vtech 2460 Answering Machine
How to get my phone to register
This is a old LS-5145
Sph-d710 purchased used. How can i register it and set up an account so I can use Virgin Mobile for my carrier?
To register it for yourself you will call virgin and let them know your phone number. If you are using an old sim card already registered to you then you will already be registered. It is the sim that has to be registered not the phone
iF YOU HAVE NOT REGISTERED JUST CONTACT THEM BY DIALING 789 IN THE UK and you will be connected to an agent who can help you set up a contract.
It is very straightforward to do
Jun 26, 2015 | Cell Phones
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
Why wont my cordless phone work no reception?
The cordless phones have to be registered to the base station (the part connected to the phone line). Perhaps they are not registered. Check you documentation for information on how to register them.
Jul 27, 2014 | Siemens Gigaset E455 Cordless Phone
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
Sep 14, 2011 | Metrologic Instruments Eclipse MS 5145...
How do I register and how do i copy one phone book to the other handsets
THE EASIEST WAY IS TO SAVE ALL YOUR OLD CONTACTS AND INFOMATION TO YOUR SIMS CARD AND PUT THAT CARD IN YOUR NEW PHONE..(OLD PHONE)...GO TO CONTACTS...SELECT CONTACT SETTINGS...SAVE TO SIMS CARD, (NEW PHONE)...SELECT SAVE TO PHONE, OR JUST CONTINUE TO USE THE SAME (OLD) SIMS CARD!
AS TO REGISTERING...YOU WILL NEED TO GO-ONLINE...IF YOU DON'T HAVE INFO ON PHONE ON HOW TO REGISTER...THAN DO A WEB SEARCH... ENTER MANUFACTURER AND MODEL NUMBER, YOU'LL FIND THE SITE TO REGISTER YOUR PHONE.
HOPE TRHIS HELPS!
Sep 03, 2011 | Cell Phones
How do I add my name to a list of names (ex. 5145
Just click on that particular and then click on edit button.Then you will be easily able to add the information.
Jan 31, 2010 | Microsoft Windows XP Home Edition
Nero6.6.1.4 serial number
1A23-5072-9041-6736-3332-2338
1A23-1063-7019-5145-4403-3265
1A23-4018-7027-5654-0171-1596
good luck.
May 11, 2009 | Ahead Software Nero 6.0 (60045) for PC
I have a jawbon and it worked fine with my motora q, but now I want to use it with my razor and cant get it to work. can you help me.
You have to remove it from your old phone. It is registered with your old phone. You go into connectivity which is usually through your setting then do it. Then turn on your new phone and go to connectivity and tell it to search wireless devices then register it to your new phone.
Dec 06, 2008 | Cell Phones
How does one get the handsets to record the new speed dial numbers on the base phone?
I'm pretty sure the speed dial numbers are programmed on a per-phone basis. Most people would not want changes on one phone's speed dial to effect the other phones. I know registering the handsets will not make a difference. If the cordless phone is working, it's registered to the base. This is required so your neighbor cannot buy the same phone model and use your phone line. In the old days cordless phones were permanently linked to one base but now you can get extra handsets on many systems and "register" the phone to work on your base.
Jul 06, 2007 | Uniden DCT-7488-2HS Digital Phone
Vtech 2460 Answering Machine Logo
23 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
