Question about AGA Kitchen Ranges
Parts for Aga Legacy 44
Does anyone know where I can order parts for my Aga Legacy 44? I only need the rubber stopper plugs that are on the underside of the burner grates as well as the silver "knobs" that sit on top of the burner surface and are to guide and secure the placement of the grates.
  • 131 Answers
SOURCE: Replacing burner grate
Go to the store and look at them side by side. Try to put the grates from the one machine on the other. No book or manufacturer will tell you if they are interchangable. They want you to but the more expensive stove - not to upgrade your burners!
Posted on Mar 31, 2008
  • 1462 Answers
SOURCE: How do you open the top of a 900DFa?
take off side panels and i think you will find that is where the securing screws are
Posted on Jul 05, 2008
SOURCE: I have GE Sealed
AH ha, I found one with these guys after a painful online hunt. I hope this helps. it was like $7.57 after the cheapest shipping option. but you can get the part number from the same link and keep hunting. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214753
Posted on Jul 20, 2008
  • 1214 Answers
SOURCE: Plastic melted on burner- how to remove?
Just allow all the plastics/rubber and burners to cool and then peel off any melted plastic/rubber. Wipe the burners with a mild cleaner like Formula 409.
You may get a little smoke and odor the next time you turn the burners on next time, or if you didn't remove all the plastic.
Reply back if you have any additional questions.
Posted on Feb 15, 2009
  • 105 Answers
SOURCE: I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Posted on Apr 07, 2009
What is the best way to store already opened wine to ensure it stays fresh?
In order to prevent oxygen from tampering with the quality of the wine you will need to find a way to seal the hole. The most efficient way that most people use for around the home is through the use of a rubber wine stopper and pump. This should give your wine an extra 2-3 days.
Here is a great quality pump and rubber stopper -
http://www.amazon.com/Vacu-Vin-0981450-Vacuum-Stoppers/dp/B000GA3KCE/ref=sr_1_1?s=kitchen&ie=UTF8&qid=1347369597&sr=1-1
Feb 03, 2013 | Wine & Spirits
Hi all i have a AGA MASTERCHEF Model 100 DF Serial number D0000124 and cant find LPG coversion Kit AGA says no kit can anyone help please Mal
Hi I have the same problem - mine is LPG and I need to convert it to NG... if anyone has any solutions I would be really grateful.
Thanks - Juliz
Feb 03, 2013 | Kitchen Ranges
I am missing a small rubber stopper inside the door of my ge front loader does anyone know what it is called and where i can get one?
i have attached a breakdown of the front and the door, can you identify the part you are talking a250bout in this picture? please let me know?
Oct 24, 2009 | GE Energy Star WCVH6260F Front Load Washer
It leaks from under the front door, escpecially when it gets to the rinse cycle. LG LDS5811WW
The Vent Kit behind the lower door panel, upper left corner has a rubber, solonoid stopper. Pressure from the spray arms overcome the rubber as the stopper hardens over time, allowing water to enter into the vent blower assembly. I found my replacement on Sears-Parts for $40 w/ shipping and just ordered it today. Be sure to turn off the breaker to the washer before removing the lower front door panel - 120vac in there, don't want no electricutions.
Oct 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Gas tube came out of gas tank
If the rubber stopper is still plugged into the tank pry it out go to a small engine shop and buy new gas line.Thread the new line into rubber stopper to poper length,plug filter (new)on end that is going in tank then pop he rubber stopper back into the tank body.Have done hundreds and it isn't hard,you may need sone WD 40 on stopper to thread line and popping stopper back in .Good Luck
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Missing parts Kinderkraft Dreamer No.305 crib.
I feel like a broken record. try parts@productsamerica.com I have a store and buy prts from them for all kinds of cribs.
May 04, 2009 | Kinderkraft Vermont Crib
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
Missing Rubber Stoppers on Kinderkraft Crib Dreamer No. 305
You can probable just put a nail or srew in for now!
Here is the 800 number for kinderkraft. They have a website but it doesn't appear to be working. 1-800-822-6748
e-mail service@kinderkraft.com
http://kinderkraft.com/main.htm
Jan 13, 2009 | Kinderkraft Vermont Crib
Theft alarm system
Check the alarm hood switch on the passenger side. Was the car in a accident ever? There should be a little rubber stopper that contacts the switch when the hood is closed. Either the rubber piece (attatched to the underside of the hood) is missing or the rubber is not contacting the switch.
Jun 30, 2008 | 2001 Hyundai Elantra
Kitchen Ranges Logo
15 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
