Dayton 125000 btu kerosene heater with E1 code
We have two dayton multi fuel heaters on site. both are 125,000 BTU and worked yesterday. this morning the blower works but the are leaking fuel from somewhere< not the tank and show a 'E1' code on the display.two units with identical problem
  • bob boyle
    bob boyle Feb 13, 2014
    This is Bob Boyle I posted the question.
  • bob boyle
    This is Bob Boyle. I posted the question. I called the 800 huber on the side of the heaters and was surprised that Grainger customer service picked up the phone. Extremely helpful and the problem was fixed in mere minutes for both units. "Dirty photo sensor" Unscrew housing pull out photo sensor assembly (no tools required) clean inside photo sensor tube and lens Put unit back together Enjoy the heat!
tbugger
  • 232 Answers
SOURCE: DAYTON 210,000 BTU OIL-FIRED HEATER WON T LIT UP
You write "FUEL SPRAYING AND FAN WAS WORKING"
If the fan was working, but the fan is not working now after replacing the whole kit, then something was installed incorrectly during the installation, possibly the rotor gap or rotor thickness is not correct or vane/vanes installed 90 degrees off.
Posted on Dec 08, 2008
SOURCE: mr heater 75,000 btu kerosene heater
I got this error when I had increased my air pressure to 5.5 lbs. Cut the pressure back to 4.5 and it has been running fine for the last three hours. At 5.5 it got WARM ... solid red hot cone and flames coming around the outside. Had been having problems with it cutting off for no apparent reason in really cold weather. Took the pump apart and cleaned it and checked for clearances and reassembled but it did not help much. Will schedule it for a total pump replacement with new filters asap. Pump parts and filter are not that bad. Should come in under $50.00
Hope this helps
I also turned the thermostat back a little off of full on.
Mike
Posted on Feb 04, 2009
SOURCE: propane shuts off after releasing start button.
I have the same problem with my Reddy heater 55-f. Is it thermal coupling or relay?
Posted on Dec 08, 2009
koolbreezes
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
How do I resolve the error code E1 on a Mr Heater Buddy Pro air 125,000 BTU
Google your heater you will find a wed site for this you can down load a manual from this site you to put in make models etc
Dec 07, 2016 | Heating & Cooling
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
I HAVE A 125000 PROPANE REDDY HEATER THAT GETS WORM, BUT WANT GET HOTTER.
heatman101
Jan 20, 2011 | Reddy HEATER RH125T 125,000-BTU...
Keep getting E1 error code, where is the fuel pump located? where is the fuel filter located on my dyna glo deluxe multi feul 170000 btu heater
The fuel pump is directly behind the fan motor as the fan motor runs both. The fuel filter is under the electrical control panel on the side of the heater usually has four to six 5/16 head sheet metal screws that hold it on. Remove the screws and then the cover comes off and this is where you will find the fuel filter.
Dec 21, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ignition starter fail
Read these troubleshooting tips. You must determine whether the failure is a fuel delivery problem or an electronics problem.
Reddy Heater troubleshooting tips
Oct 19, 2010 | Reddy HEATER RH125T 125,000-BTU...
I need a manual for laars lite 2 125000 btu
Go to the Jandy web site, there you can look up your model and down load a pfd manual free
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Dayton e51 kerosene heater
We have a 3VE53C 400,000 btu heater , the fans will come on you can hear the ignitor and fuel will run out of the front of the unit. It trys to fire twice and will not. Then you get the E1 error sign.
Jan 21, 2008 | Dayton E52 Utility Heater
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
