Question about Brother Sewing Machines
Artisan 723 overlocker
The machine is working but it dont feed the materiale..what can the problem be?
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
Jul 20, 2016 | Sewing Machines
Looking for free download for user manual for Elna 792D differential feed overlocker
go google and type in --- workshop manual for elna 792d overlocker---and there will be a pdf version to down load
on the same sites you will find user manuals and probably a parts manual as well that you can down load
that way you will get a book on how to fix and a book on how to use use
Dec 15, 2015 | Elna Sewing Machines
I need instructions for artisan 300 overlocker
Hi Karen, did u get any replies? I'm in need of an instruction operator handbook also
Nov 06, 2011 | Sewing Machines
I bought an empisal overlocker and sewing machine more than two years ago at Game Centution. I used the sewing machine a few times. I tried to use the overlocker but without success and just put it away...
Hi Bonita
Can you use the sewing machine? Does it work? I am also thinking of buying one but not sure if I should. They're on sale now at Makro for R899 =- what did you pay for yours?
Aug 17, 2010 | Sewing Machines
I just bought a Yamata BL4-434D overlock machine,
Put 4 colours of thred on the machine , set all tention knobs to 0 stitch and see what colour is not tight, adjust the colour that is not tight. Also use jersey ball point no 80/12 needles it work on all material E-Mail me wcbotha@yahoo.com From Willem SA
May 10, 2010 | Yamata BL4-434D
Need manual for singer serger model # 14sh654
Hi Wendy. Go to this web address and you can order what you need. http://www.sewingmachineparts.net/index.html
Please remember to rate my answer. thanks.
Feb 05, 2009 | Sewing Machines
Have a Necchi 3205FA and trying to figure out how to set it up for serging. DVD wasn't much help.
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Nov 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
20 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
