Question about Discovery Channel Discovery Kids - Rocket Ship Projection Clock
Discovery rocketship alarm clock instructions
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi
https://prezi.com/vgxxmjfbc1ya/sharp-alarm-clock-inustructions/ Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
Nov 05, 2017 | Sharp Audio Players & Recorders
How to change time zone discovery channel tx2500 weather station
After u add new battery's let is sit for about 10 min then press and hold the alarm button until in changes to the next time zone
Oct 23, 2013 | Discovery Channel Audio Players &...
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
Lost instructions for Shift Model No 1624965
I am trying to find the instruction manual for the Shift 3 FC Model 1624965 also!! The back says Made in China, Merchsource LLC, Foothill Ranch CA. Anyone? Just found an interesting report on Merchsource. See link: http://www.ripoffreport.com/r/merchsource-llc/foothill-ranch-california-92610/merchsource-llc-discovery-kids-scam-distributor-for-discovery-kids-foothill-ranch-califor-677328
Maybe we will NEVER figure out how this clock works..
Mar 23, 2013 | Measuring Tools & Sensors
Discovery rocket ship clock alarm off
You have to press the alarm setup, then press the up button. This turns the alarm off completely. If you want the alarm to go off again tomorrow you will have to set it again.
Feb 10, 2013 | Discovery Channel Discovery Kids - Rocket...
How do I reset alarm?
1. Press the Alarm Set button to display the current alarm.
2. Hold down the Alarm Set button for a few seconds. This will cause the time to flash.
3. Press the Up/Down buttons to reset the new time.
4. Press Alarm button once more to set minutes. Press again to exit alarm setup.
Cheers!
Jan 22, 2013 | Discovery Channel Discovery Kids - Rocket...
How do I turn off the alarm clock? It keeps coming on every 5 minutes
When you are in alarm setup mode the Up button Is your on-off switch
Dec 27, 2012 | Discovery Channel Discovery Kids - Rocket...
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Jan 05, 2010 | La Crosse Radio Controlled Atomic Clock
Discovery Channel Discovery Kids - Rocket Ship Projection Clock Logo
156 people viewed this question
Top Discovery Channel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Discovery Channel Audio Player and Recorder Expert? Answer questions, earn points and help others
