Question about Panasonic KXDT333 Phone
Take off loudspeaker - Panasonic KXDT333 Phone
How can I connect it to get the most power out of it?
What load is the amplifier designed to drive? It will only deliver maximum power into the optimum load. The loudspeakers are probably 4 Ohms, but the amplifier may well be able to drive 2 Ohms per channel. This means that you need to fit two more loudspeakers This is probably not possible. Alternatively, if the amplifier can be bridged AND can safely drive 2 Ohms bridged or 1 Ohm per channel, you should connect the two loudspeakers together (+ to + and - to -) and connect them to the amplifier output terminals indicated for bridge (often Left + and Right + but sometimes Left + and Right -). If the amplifier can't drive 2 Ohms bridged, do not connect the loudspeakers together, buy another amplifier and connect one loudspeaker to each, with both amps in bridge mode.
Remember that loudspeaker and amplifier power ratings are always massively inflated in the manufacturers' data, often by a factor of 4 and sometimes by 10 or more. You speakers may not be able to cope with a whole amplifier each, so proceed with caution.
Jun 07, 2015 | Pyle 2 Channel 4000 Watt High Power MOSFET...
The loud speaker on my g1 doesn't work how do I replace
  1. 1st OF ALL, YOU WILL HAVE TO UNSCREW THE PHONE
  2. THEN YOU WILL REMOVE THE BAD LOUDSPEAKER
  3. THEN YOU WILL HAVE TO GET A NEW LOUDSPEAKER @ ANY PHONE REPAIR SHOP
  4. THEN FIX THE NEW LOUDSPEAKER IN THE PHONE
  5. TEST IT
Jan 10, 2011 | HTC G1
How to switch on loudspeaker in nokia 3110?
Dear sir,
when the call is in duration there is the option of Loudspeaker in the extreme left/right of the cell fone. :)
From there you can switch on loudspeakers. :)
Take care.
Dec 14, 2009 | Cell Phones
Radio works well in headset mode but has a lot of disturances in loudspeaker mode
Hi Friend,
When u are hearing the Radio or Music Player in your mobile by using the headset its clear but when u are using thro' loudspeaker its not clear because of below reason,
1.There may be problem in the Speaker(LoudSpeaker).The Solution is u may change your speaker by giving to the Service Center.
Regards,
Ayyasam
May 31, 2009 | Nokia 7610
I want to increase volume of caller.
To actually answer a call using loudspeaker, press the top-left button (options) and then the middle select button (with the option "Loudspeaker" highlighted). You can do this even when Keyguard is activated. (I just checked.) It means pressing two keys but at least it actually answers using the loudspeaker.
To make a call, the only way I can see is to dial first and then press the Loudspeaker button while the phone at the other end is ringing.
Mar 04, 2009 | Nokia 6230i Cellular Phone
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Oct 16, 2008 | Onkyo TX-SV444 Receiver
Receiver puts up PROTECT message
Not enough information provided - problem is likely impedance / load related. Receivers / amplifiers usually self-protect when the resistance they expect to see as provided by a loudspeaker is too low, or bypassed by a shorted circuit. Check your loudspeakers' impedances - impedance is measured in ohms. The loudspeakers' native impedances, as-built, may be too low for the amp. You can check the amp's requirements in the spec's section in the manual. If the numbers check-out, then put a multimeter on each loudspeaker to check their impedance. A failed loudspeaker can have a tanked impedance, thereby cascading instability to the amp. If you are driving a dynamic arrangement of loudspeakers with room-borne volume controls, a multi-meter won't likely reveal accurate impedance, you will need an Impedometer to test. And, most importantly, make absolutely certain that there is not a single strand of conductor errantly shorting at all terminations.
Oct 05, 2008 | Audio Players & Recorders
Loudspeaker Nokia N81 - 8 GB
do you have ab luetooth headset connected?
if so try closing the connection..
May 21, 2008 | Nokia N81 Smartphone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Panasonic KXDT333   Phone Logo
15 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
