Question about Canon CanoScan LiDE 700F
Error 2, 142,0
Calibbrate scanner gifs error
No pdf format on scanner file type
You can scan document to multi-page TIFF file anf then use a TIFF to PDF Converter to convert all pages from the TIFF document to PDF file.
Jan 21, 2013 | Canon Pixma MP480 All-In-One InkJet...
Where can i compact a gif file online for free?
GIF files are already just about as compressed as they can be, and I don't know what you mean by compacting online. If you want to try compacting the files further, you can download compression software and do it on your computer. WinRAR or WinZip are free to try but you need to purchase them for full operation. 7-Zip is 100% free. If I'm completely missing what you want to do, please post a follow-up comment with some more information and I'll try to be more helpful.
May 15, 2011 | Computers & Internet
By winodj_d on Nov 23, 2010 the analyze of the car gifs still a p420 error. After replacing the lambda sensors (oxy sensors) and the katalysator. on a chrysler pacifica 2005 fault has been...
CODE PO420 - CATALYTIC EFFICIENCY BELOW NORMAL BANK I POSSIBLE CAUSES - BASE ENGINE PROBLEMS HIGH COOLANT OR ENGINE OIL CONSUMPTION- CATALYTIC CONVERTER DAMAGED OR HAS FAILED - AIR LEAKS IN AT THE EXHAUST MANIFOLD OR EXHAUST PIPES -YOU NEED A CODE SCANNER TO ERASE CODE.
Nov 25, 2010 | Chrysler Pacifica Cars & Trucks
If I need to send some papers to some other place and it says I cant it want go through because it needs to be changed to gif image or pdf or jpg so what do i do how do i change this thanks
You will need a scanner or a printer with a scan function. When you scan you can choose what format you want to save it as.
Gif and jpg are images that can be opened with any graphics program. Pdf files require Adobe Reader to open them.
Hope this helps.
Thanks for using Fixya.
Dec 05, 2009 | E-Machines Emachine T5026 power supply **...
Error 5010
On a Canon machine 5010 is a scanner error, stuck, light burned out, etc.
Sep 09, 2009 | Office Equipment & Supplies
All in one Cannon Pixma MX860 inkjet
None go to : tp://www.usa.canon.com/consumer/controller
for support: Tech Support spacer.gif spacer.gif red_arrow_greybk.gif Frequently Asked Questions red_arrow_greybk.gif Support by E-mail red_arrow_greybk.gif Support by Phone
Jun 26, 2009 | Office Equipment & Supplies
AM NOT ABLE TO SYNC OVER PICTURES THAT IS ON COMPUTER OVER TO MY MP3
Are your images .gif or .jpg format?
To reformat your images open them in whatever program you prefer and click Save As and either type in the name followed by .jpg or .gif or under the naming bar there should be another bar indicating format. This should be a drop down selection box. select GIF or JPG.
Apr 12, 2009 | GPX ML648B MP3 Player
Can't save gifs
I had the same problem and googled a few forums with zero results.. so i found out what the problem was atleast for me... same error message when you try to save a GIF file "Unable to finish GIF Optimization process" What you need to do is this.
When you click on the Optimize tab you will get the same message again.. so click ok.. then at the very top second to the last icon is the Optimize Panel.. Click on it so the Optimize Panel comes up... then click on the Locate Palette tab.. and tic the "Preserve Local Palette" then you need to also tic the "Local Palette for all frames" once those two options are checked.. you will be able to save GIF files and the error goes away.. atleast for me this is what solved my problem..
Good Luck
Jan 30, 2009 | Ulead GIF Animator 5.0 for PC
Error (-48)
Error(-48) is somekind of hardware communication error. The easiest way to fix it will be to flash the firmware. Here's how to do it.. It will take a while(around half an hour) but its worth it and will also improve the sound clarity of your phone.
What u need :
1) Motorola Driver
2) RSD Lite or Flash&Backup 3
3) Monster Pack(Flash update for(Lseries including SLVR)
Firstly you need to backup all your files that stored on phone memory because it will delete everything in your phone when you flashing.
Start RSD Lite and let it connect to your phone. If your phone is not detected (and you are certain you have everything installed), disconnect the data cable, then shut your phone off, and manually put it into bootloader mode. You do this by pressing and holding down the "*" and "#" keys while pressing and holding down the on button until you see text display on your screen. Now connect the phone back to the data cable. Now click the button labeled "...".
http://www.hackthel7.com/gif/flash1.gif
This will bring up the open file dialog box. Find the file you want to use (in this case select your monster pack file) and then click the button labeled "Open".
http://www.hackthel7.com/gif/flash2.gif
Click the "Start" button. Now you should see various messages displayed on the screen as the program processes each code group and does various other things.
http://www.hackthel7.com/gif/flash3.gif
This is what the phone will display during a flash:
http://www.hackthel7.com/jpg/upgrade.jpg
After it's finished and your phone has given you a confirmation tone, you can click "Close" and disconnect your phone from the cable and check out your changes.
If you should get a message like this where the program seems to hang:
http://www.hackthel7.com/gif/flashstuck.gif
OR
http://www.hackthel7.com/gif/flash4.gif
Don't panic. Just close the program, chance are your phone is just fine. Sometimes this happens. This is usually caused by a checksum error. There could be more serious cases where you phone appears dead. In this case try to reflash your file again. You could also try reflashing another file.
Sep 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Scanner error
Try uninstalling and reinstalling the driver. If it occurs again, the the manufacturer of the scanner of yours may have some special thing (security) in the flatbed of the scanner. Like for example scanning money or so.
Jun 12, 2008 | HP Office Equipment & Supplies
Canon CanoScan LiDE 700F Logo
122 people viewed this question
old marine
old marine
