Question about Samsung SCX4623F AllInOne Laser Printer
Scx4623f problem with printing right side dark and left side deem
While printing right side is dark print and left side of the paper is very light plz help me
  • Samsung Master
  • 783 Answers
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Posted on Feb 11, 2014
  • 217 Answers
SOURCE: Samsung CLP-510 Print Quality problem
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Posted on Jan 17, 2008
SOURCE: Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Posted on Jan 05, 2009
  • 670 Answers
SOURCE: My Samsung CLX-3160FN prints with
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Feb 27, 2009
myjosh007
  • 530 Answers
hi im josh try this: Understanding Potential Problems Printers are mechanical devices with lots of moving parts. And any time you have moving parts, you have something that can break or wear out over time.
So when you click the old print button and nothing happens, what are the likely causes?
First, you might have the wrong printer driver installed in Windows. You might have either simply selected the wrong driver for your printer, or Windows might have mistaken your printer for another model, or the driver selected might be out of date. While we're in this area, it's also possible that various aspects of your printer setup might be incorrect, which can cause some highly unusual problems. You should also check your font setup because fonts themselves can cause perplexing problems if they're not installed correctly.
In addition, any new input or output device you've installed since you installed your main printer could have changed your printer's settings. (It's kind of like the last device installed gets dibs on key system settings.) If you've recently added a scanner or a digital camera or fax software or anything like that and then experienced printer problems, try uninstalling your printer (and all printer drivers) and then reinstalling your printer so that your printer is now the last device installed—and thus controls key system settings.
It's also possible that if you're printing large or graphically complex documents, you might not have enough disk space or memory to print. Make sure that you have plenty of both, because Windows needs all the space it can get to complete the printing operation.
Finally, you could have real printer hardware problems. These problems range from the mundane (you're out of paper, you forgot to turn on the printer, a cable came loose) to the fairly serious (your printer is broken!). Check all your cables and connections and make sure that your printer is actually turned on.
The bottom line is there are a lot of things you need to check if you have printer problems, both hardware- and software-related. So if you have printing problems, hunker down and plow through the problems/solutions section, coming up next.
tip
One of the best ways to track down a printing-related problem is to use the Windows Print Troubleshooter, found in the Help utility.
Problem: Your Printer Prints, but Output Is Smudged or Garbled If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time
  • good luck
Posted on Mar 06, 2009
  • 670 Answers
SOURCE: Our Laser printer doesn't print on the left had
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Posted on Jan 19, 2010
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Stop two-sided printing
please check
1) the tray
2) rear cover
3) front cover
Finally only fuser unit. needs to be opened.and checked for paper jam.
Best Regards and happy wishes
Mar 10, 2012 | Samsung SCX4623F Laser All-in-One Printer
IBM 6400 Matrix Printer is printing twice over a previous line it seem on to happen once or twice per page of text there seems to be no issue with the tractor feed no drag on the paper source and the test...
Might be your gap is set to high. try moving the right lever from A to B for example and see if it clears it out. Also might be your parallelism, you will find to hex screws on the right and left of the platen assy that u can adjust. This will balance out the shuttle if one side is printing to light and another is printing to dark. Rory 708-597-4222
Oct 07, 2011 | IBM 6400 Matrix Printer
Prints lighter on left side of most pages. Even with new toner and fuser and toner darkness turned up to 9 or 10.
This is a bit tricky, but try it
remove the toner cart and lower the top cover about 1/2 way. Look inside and you will see 2 grey rollers hanging from the top on 2 arms. Move the right side arm to the right and grey rollers will fall out (they are as wide as a sheet of paper)
use a light scrubbing with a damp cloth to remove the grey, the rubber should be a tan colour. Dry them off well, insert the left side first (cover in the 1/2 closed position makes moving that right arm easy. install the toner cart again and print a page. It should be nice and dark now, just make sure the rollers are dry when you reinstall them.
Jan 11, 2011 | Office Equipment & Supplies
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Lexmark x5150 color printing issues
Sometimes ,poor print quality may be due to ink build up in the maintenance station ..
Your ink cartridges stay in the maintenance station when not in use. Depending on the printer model, the maintenance station may be located on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
To access the wiper for cleaning purposes:
Unplug the power cord from the back of the printer.
Move the ink cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right-hand side of the printer.
Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Light print problem
excellent idea! we have a samsung scx 4100, when scanning produces light print on one side of the page (left side). How does the scanner removed. to get to the scanner.
Mar 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX4623F AllInOne Laser Printer Logo
102 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
