Question about Water Heaters
Had boiler serviced last week but now wont start when i switch it on
  • Water Heaters Master
  • 3,368 Answers
Since it was serviced last week contact the service people and let them know what is happening, it appears there repair was not completed properly.
Posted on May 03, 2014
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Intermittent lockout
One of or both of two problems. The ignition board could be on its way out and needs to be replaced and or the flame sensor/igniter may be dirty and need to be cleaned or the porciline may be cracked and it's grounding out when it try's to light. I would replace both anyway and problemed solved. Good luck
Sep 08, 2012 | Water Heaters
Combi boiler will not fire up for hot water or heating.
check tops of spindles at radiator valves for leaks easy repaired set pressure to .8bar setting at 1.5 may be make overpressure and blow off through high/pressure releasese valve
Nov 30, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Boiler kept shutting down.Re-starts but drops not keeping pilot.
there ic a low water cut-off on all boilers, also a over pressure switch that can shut down the unit. You should really call a service company out to look at the problem due to the potential of a serius problem with thee unit and see whats is the problem with the unit. Boilers can explode and do allot of damage to a person and property if this happ[ens. GOod Luck
Jan 07, 2009 | Water Heaters
Water Heaters Logo
21 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
