Everflourish emd 300How do I connect the different phases cable)? Thank you
How To Convert Y Connection 3 Phase Motor Which Burnt Into A Delta Connection?
Delta is entirely different connection.... look here:
https://www.google.co.uk/search?q=3+Phase+Motor&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=TWKZU9jpJobSOe3lgdAD&ved=0CEMQsAQ&biw=1534&bih=846
Jun 12, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
TYPE EMT757-UL
You might have Everflourish EMT 757 timer.
Copy following link to identify timer and download possible manual(s)
http://waterheatertimer.org/Woods-timers-and-manuals.html#seven
Timer models change, and sometimes a different suffix can be totally different timer model than another timer with nearly identical number.
Add a comment and describe timer in detail.
Nov 03, 2012 | Hardware & Accessories
How can i get single phase power from my 3 phase generator
I have not wire this myself
Wiki says under heading of single-phase:
http://en.wikipedia.org/wiki/Three-phase_electric_power
Single-phase loads may be connected to a three-phase system in two ways. A load may be connected across two of the three phase conductors or a load can be connected from a live phase conductor to the system neutral. Single-phase loads should be distributed evenly between the phases of the three-phase system for efficient use of the supply transformer and supply conductors. Where the line-to-neutral voltage is a standard utilization voltage (for example in a 230 V/400 V system), individual single-phase utility customers or loads may each be connected to a different phase of the supply. Where the line-to-neutral voltage is not a common utilization voltage, for example in a 347/600 V system, single-phase loads must be supplied by individual step-down transformers.
So it sounds like you take 2 legs of the 3-phase.
or
Take one leg of the 3-phase and connect to neutral ... neutral could be a ground rod.
I would put a meter on that circuit before hooking up my power saw.
Nov 17, 2010 | Electrical Supplies
Were canI obtain a everflourish pt1007p manual
You can get that here:
http://manualfox.com/de/link/everflourish.htm
This is the english site:
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fmanualfox.com%2Fde%2Flink%2Feverflourish.htm
Nov 08, 2010 | Hardware & Accessories
Does this machine run off 240volts or three phaze regards gary
If I undersatnd correct your question is if it can work with single phase or three phase.
You should first check the lable of the machine which is a silver plate and which it can be found outside the machine so you can check the voltage if it is 220-240 or 110V. Also you can find the total load in Watt.
You can check also to see how many wires are incuded in the power cable. If you find only three then you can only be connected with single phase. If you find five cables then you can connect both single phase and three phase. In the case you want single phase then you can connect the three phases as one. The only care is that the supply isolator on the wall to be able to supply the required total power mention on the label of the machine.
Good luck
Apr 16, 2010 | Astoria Argenta SAE-2 Espresso Machine
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
