Which is negative and positive leads on compaq nx9600
Positve lead and negative lead on laptop
  • 5 Answers
SOURCE: PAT TESTING A LAPTOP AND LEADS
Automatic RCD Testing needed
pl contact me
regards
Senthil007
sundari_changi@yahoo.com.au
+91 9789227782
Posted on Dec 15, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: CONNECTIING COMPAQ LAPTOP TO MY NEW 42"LG LCD TV
If the cable from the laptop is connected to the TV, you've selected the VGA input and see no signal, you probably haven't enabled the laptop's VGA output connector. Somewhere on the keyboard will be a function key with a little monitor screen on it. Hold down the F or Fn key and press the monitor key and it will switch on the external monitor connector. On some monitors, the first press shuts off the laptop screen when it turns on the external connector. If yours does that, press the key a second time to turn the laptop screen back on.
Posted on Feb 16, 2009
paulrelliott
  • 69 Answers
SOURCE: hi compaq presario will not start up have used new
It's probably overheated in the past usually when they're set down on a bed & can't breath as the cooling fan is sucking air in from underneath. when that happens the fan sometimes needs replacing as they have the temp sensor built in & if that or the fan has gone then the laptop wont start, see if the fan moves at all when it tries to power up!
that usually proves the sensor is gone, but it's moretime something in the safety circit stopping it from starting up!
most shops can repair this easier if you give them a pointer as to what may be wrong as if you've left it in places where it cannot breath then tell them tha & they will check the fan first!
Hope this helped !
Posted on Sep 23, 2009
adamfjeld
  • 1508 Answers
SOURCE: connecting 2 UB6120ZH batteries for a peg perego jeep.
if it is 2 6v batteries wired in series, then the main leads would be connected to the positive of one battery and the negative of the other battery, and then another wire would connect the remaining terminals of the two batteries together
Posted on Jun 07, 2012
SOURCE: How do I data fatory reset an hp compaq nx9600
Try pressing [F11] repeatedly on Start-up, to access the Factory Recovery Partition.....
However, PLEASE note that you will NOT find Windows 7 drivers for your laptop if it is that old. (confirmed, HP only supports XP on that model.)
IOW....*IF* you could manage to get win7 to install on it, it is HIGHLY likely that parts of it would not work....video, network, cardbus slot, audio.....all of these would need windows 7 drivers to work properly.
you would likely be able to see a monitor image, but not be able to change the resolution much (stuck at 800x600) and the others....would be hit and miss. and if your network adapters (LAN and WLAN) did not work, I'm not sure of what use it would be to you.....
This is one of the pit-falls in Laptop/Notebook ownership. Although some models have lasted through more than one OS, they are a tiny minority.
Posted on Sep 04, 2012
Had to jump car cuz battery was and dead and tmsp is all lines how do i reset it
to jump start a car the following procedure applies
place the positive lead from the jump battery onto the positive terminal of the car battery (clip on)
place the negative lead of the jump battery onto the engine ( clip on) not the car battery terminal
this prevents power surges through the ECM
remove the jump battery is the reverse procedure
to reset an ECM use a scan tool
there are jumper leads now on the market which have surge protection in a lead so in that case positive to positive and negative to negative
Sep 04, 2015 | Cars & Trucks
I want to connect these batteries to form battery pack for prepper use. How can I do ie
conect a lead to the negative side of one battery, join the positive and the negative of the other battery conect a lead to the positive of the second battery, lead from 1st batt. is negative and lead from 2nd is posive to produce 3.volts
Apr 10, 2013 | Electronics - Others
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
Connecting 2 UB6120ZH batteries for a peg perego jeep.
Jun 06, 2012 | Toys
Where is the starter of toyota corolla 95 and how do i remove it?
Locate the battery. (right side front engine bay) look down and to the left. see that little cylinder with the fat wire going to it? that's the starter. Its in between the transmission front side, and the radiator. You should be able to see the long bolts going into it from the back side of the starter. First remove your battery and set it aside then open the plastic access cap to get to the terminal. Remove the wiring. once wires are free of starter, remove the long bolts. slide starter towards the right of the engine bay. It should be free now and in your hand, ready to be tested or replaced. To test it, get a second person to help. get a set of jumper cables. connect the negative side of the battery to the metal casing of the starter and connect the positive side of the jumper cable to the places where you removed the wires. Hook up the negative battery lead of the jumper to the negative battery terminal. Touch the positve lead to the positve terminal. Warn your buddy before doing this because the starter will try to twist as it spins up. If the starter spins, and you see the gear (throwout) push forward towards the tip, then starter is okay. Do this test, let me know what happens, and I can tell you what to check next.
Nov 22, 2010 | 1995 Toyota Corolla
Won't start
It is usually marked on the casing. +(or a red marker around the pole) is positive. If you havent removed the battery connect a bulb between one of the poles a piece of bare metal (ie engine). If the bulb lights up you're on the positive. If you have already removed the battery use a multimeter and measure voltage across the poles on the battery, if the meter gives a positive reading the red test lead is on the positve. If it gives a negative reading ie -12.35V(digital meter) the red is on negative. If you have an analogue meter(a meter using a needle) it will swing to the left when red lead is on neg.
Jul 26, 2010 | 1996 Lexus ES 300
Alpine 3530 Bridgeable 4 channel power amplifier how do i connect the wires/speakers
Use the left and right to connect the positive and negative to the respective speakers in the right and left. Please make sure of the polarity and so be cautious. next you can connect the sub woofer from the left and right channel as the amp is bridgeable. Use the lead to connect from the R- positve to L negative. test and check the phasing of the speakers, must get good low bass or else you can reverse the sub woofer and check again. If you ae having frint speakers connect accordingly the the other channel. Helpful Good day
Jul 12, 2010 | Alpine Car Audio & Video
Battery is good light,dontcome on horn dont blow engine dont turn over
check the ignition switch and the leads goin from the batt to the engine and starter.
Oct 21, 2009 | 1992 Honda Accord
Voltage drop test
First, check battery post to cable connection: positive meter lead on battery positive post, negaitve lead on battery's positive cable clamp. Crank the engine and note the reading. A good connection should have zero voltage drop. Second, check the positive cable: positve meter lead on positive battery clamp, negative lead on starter terminal connector. A good cable will show a voltage drop of .2 volts or less while cranking. Third, check the starter connection: positive meter lead on positive battery terminal on the solenoid, negative meter lead on actual starter stud. A good connection will have a voltage drop of near zero volts. Now to check the negative side of the circuit. Total drop on the ground side should be .3 volts or less and can be checked by placing positive meter lead on starter housing and negative meter lead on battery ground post. Take your reading while cranking the engine, and be sure your connection at the starter is solid and clean. If total voltage drop on this side of the circuit is excessive, complete testing at all connections in the same fashion as the positive side of the circuit. Check the following: between battery post and clamp (zero voltage drop), cable end at battery to cable end at engine. (.2 volts or less), cable end at engine to engine itself (near zero voltage drop), and finally between starter housing and engine block (.1 volts or less).
To read the entire procedure for all automotive systems read this artile:
http://www.engine-light-help.com/voltage-drop.html
Aug 31, 2008 | 1997 Chevrolet Blazer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
