Question about Lil' Rider FX Wheel Battery Powered Bike Color: Black
The wheels keep disconnecting the wires to the battery when assembled.
Need more detailed instructions on how to properly assemble the bike - especially the wheels so that they don't disconnect the wires to the battery.
NEED INSTRUCTIONS FOR ASSEMBLY SINCE NONE WERE PROVIDED. WHERE DO I GET THEM?
Bikes do not come with assembly instructions, as assembly includes adjustment of various parts, not just installing pedals, seat etc. Said adjustment may require specialized tools and definitely requires proper knowledge or instruction. The best option if you cannot afford to have a bike shop assemble it is to see if there is a bike co-op in your area - link: Community Bicycle Organizations They will be able to assist you and will have the proper tools. Otherwise you would have to look up the procedure for each item (adjust brakes, adjust front/rear derailleur, adjust hubs, etc.). Best sites for doing so are:
Repair Help and Education
Sheldon Brown Bicycle Technical Information
I see you asked previously about surrey assembly. As you still provide no details about make/model the above info is the best available advice.
May 23, 2016 | Cycling
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
How do I assemble a Stowabike City Compact Folding Bike
"Before riding the Stowabike for the first time you have to assemble the the handlebars, front wheel, pedals and the back rack. All the instructions how to exactly put everything together will be delivered with the Stowabike." See more assembly info in the link below, where the above text originated.
Stowabike 20 City Bike Compact Folding Bike
What's most important is the adjustment done once the bike is put together. For safety and proper operation the brakes and derailleurs (shift system) need to be properly adjusted, and sometimes the hub bearings as well. You may want to have a bike shop assemble it, or see if your community has a bike co-op, where you can use their tools and get help.
Feb 04, 2013 | Cycling
Turn indicator/wiper switch assembly replacement instructions please?
steps required to remove and replace indicator switch assembly.
1.disconnect the battery earth lead.
2.from the rear of the steering wheel remove the screws retaining the horn pad..
3.lift the horn assembly away from the steering wheel far enough to remove wiring.
4.Once that is done then move to the next step.
5.Remove the locknut and steering wheel nut .
6.then mark the end of the steering shaft and the steering wheel to correctly relocate and install in same position.
7.then with the correct tool remove the steering wheel from shaft.
8.then once the steering wheel is removed you can then move on to removing the lower steering column cover screw and then remove cover.
9.disconnect the wiring from the multi point connector under instrument panel.
10.release and free wiring harness.
11.unscrew and remove the hazard switch knob.
12.remove the dipper-wiper switch securing screw and manoeurve the switch upwards.guiding the wiring through the column.
13.you will actual find there are 3 phillip head screws securing the switch to lever switch to the combination switch.
14.when putting this assembly back to together just follow these steps in reverse..
hope you find this helps you
Aug 03, 2012 | Holden VK Cars & Trucks
Hi! I need the assembly instructions to assemble a new unassembled 2010 Suzuki Haojue AX100 motorcycle. Were can I get assembly instructions for this motorcycle, or can you find these for me???
It ain't rocket science. Have the dealer put acid in the battery so it is ready to go into the frame pocket. It should come out of the crate with the rear wheel already mounted. The controls on the handlebars should already be mounted as well. Put the handlebars in position and bolt them in place. Put a box, or whatever you have, underneath the frame to get the front forks higher than the axle on the front wheel. Now put the front wheel assembly in place and insert the front axle. Add the washers and nut and tighten the nut. If the bike has headlights, remove the glass bulb assembly and hook up all the wires. Match the color coded wires; Black to black, blue/white to blue/white, green to green and so on. Mount the shift and rear brake levers if not already mounted. Ad fenders and turn signals and whatever else needs mounting. Install the battery, red wire to the positive battery terminal, black wire to the negative terminal. Now put some gas in the tank and turn on the gas petcock at the bottom of the gas tank. Note; some bikes do not have an actual valve for the gas. Turn the key on and watch for smoke from the wiring. If you hook the wires up wrong they can burn. If all is well, ( relax, all should be well ), go ahead and kick start the engine. Again, watch for anything odd. Now re-mount the headlight assembly and go for a test ride. Adjust the clutch and brake levers as needed. All done! You may want to ride over to the dealers and let them look at it just to be sure all looks okay.
Mar 11, 2011 | 2001 Suzuki AX 100
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
With Air Conditioning
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
Nov 05, 2010 | 1989 Ford Escort
Instep bike trailer assembly
This is the manual for the model that you have. Pictures included. http://www.instep.net/productInstepPDFFiles/168pdf-1pdf
May 25, 2010 | InSTEP EZ Bike Trailer
Horn wont stop
The button behind steering wheel and airbag may be stuck. I would remove the fuse for now until you can get at it..
Aug 28, 2009 | 2003 Mitsubishi Galant
Lil' Rider FX Wheel Battery Powered Bike Color: Black Logo
Top Lil' Rider Cycling Experts
ray gallant
Michael Smalls
Michael Smalls
Level 1 Expert
Are you a Lil' Rider Cycling Expert? Answer questions, earn points and help others
