Question about Honeywell Heating & Cooling
Honeywell fan limit control
I had a blower motor go bad. I replaced it with the same motor of a different brand. Now my blower runs constantly and my igniter will kick on and off before heating the house. What will cause this? How can I check to see if the fan/limit control is bad?
  • Casey Mittan
    Casey Mittan Feb 13, 2014
    I found the problem. The new blower motor was not working correctly. I replaced the new motor and it is running fine now.
  • 101 Answers
FIRST I WOULD MAKE SURE YOUR FAN IS NOT SET TO "ON"
IF YOUR FAN LIMIT IS ADJUSTABLE TRY DIFFERENT SETTINGS CONSTANT FAN IS NOT THE END OF THE WORLD IT WILL KEEP THE TEMP IN YOUR HOUSE EVEN. AS FAR AS THE IGNITING IF YOU GET A FLAME AND IT CUT OUT A FEW SECONDS AFTER I WOULD CLEAN THE FLAME SENSOR.
Posted on Dec 11, 2014
  • 24 Answers
Many things could bring this on. Most commonly a high limit is open tEllington the unit that the furnace has a cracked heat exchanger.
Posted on Oct 28, 2014
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
I show voltage to the blower motor but it does not start when i press fan on the thermostat? Bad relays or bad blower motor?
Sounds like a bad motor. I don't know if your blower motor has an external starting capacitor and / or a running capacitor. If There is a starting capacitor and it's faulty , that would prevent the motor starting and turning.
Jun 01, 2014 | Honeywell R856B 1002 R856B1002 Fan Control
I have a bad fan/limit control Honeywell L4064A 2188.What would sbe a suitable replacement part number?
take original honeywell model # go to honeywell site and look for original part # and it will give you cross reference #s
Nov 05, 2013 | Honeywell L4064B2236 Fan/Limit Control...
Fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the cold...
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Dec 20, 2011 | Honeywell L4064B2236 Fan/Limit Control...
Carrier oil furnace model 58BMA155-20(FORCED HOT AIR)i had changed the blower motor & honeywell st9103a128 fan control board.now the blower motor won't shut off until the breaker is turned off.i...
You need to check the wiring to the limits and safety devices with are in a number of locations, make sure all connections are tight.The most common cause for the blower to run is the high limit device which is the one mounted above the burners on the flat metal panel with two wires.
Nov 03, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Blower fan running constant after new fan and limit switch installed.more info.Honeywell-tradeline.L4064B 2210, combination fan and limit control, adjustable fan differential with manual fan switch, flush...
Here's my best shot.
Check the temperature settings for the fan switch.
The low OFF setting should be about 100 degrees.
The ON setting should be around 150 degrees and this is the setting that "makes" the ON contacts.
The HIGH LIMIT setting should be about 180 degrees.
If these are set, can you use a meter to see if the FAN ON contacts are closed?
Lastly, it appears that one hot line should go to one side of the blower and the other hot line should go to the bottom FAN terminal with the other side of the blower being fed by wiring from the top FAN terminal.
Good Luck. Gary
Feb 21, 2011 | Honeywell Heating & Cooling
When I set tstat to call for a/c, compressor outside comes on. Blower on furnace does not. When I manually rotate fan limit switch on furnace wall, blower comes on, blows cold air, and then goes off when...
blower relay bad or no call from stat on green wire to run fan jump red on stat to green if fan comes on stat bad if no look for fan relay turning the well switch bypasses the relay hope this helps
May 24, 2009 | Heating & Cooling
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
BLOWER FAN WONT SHUT OFF WHEN THERMOSTATE IS OFF
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
Aug 19, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
1,016 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
