Question about Beats By Dr Dre Beatbox iPod Dock
Beatsbox stopped working, need a repair shop
Turned it on , at that moment it blue out a my breaker, and my beats box stopped working . I have been trying to take it a part to repair it. And I can not find the best way to do it. Can ant one tell me what comes off first so I can check the fuse.
I had a power outage. control board is blinking 1 blue light on the freezer side. Bulb works inside. nothing works
Lilly Spence... hello,
There is several quite obscure "things" that could have happened to your refrigerator...
Presuming OWNERS MANUAL "RESET" failed.
I can only talk in GLOBAL/TYPICAL terms without your make & model number... If you don't mind spending a wad of money and learning nothing in the process... you need only find a competent repair person... they will pluck off the bottom grill ... pop out the "black box" with your PCB (printed circuit board)... here-in-after
we will call that your "power control board" and either find that bad solder joint... or discover the board resident relay or transformer DID NOT SURVIVE...
On my refrigerator 22 year old AMANA (which I love) that part has become quite rare (just because of time... but there are repair services that can refurbish OLD packs (10 days end to end & $100 - $200 later)
BUT THE NEWER, SMARTER... high end refrigerators
have a real "Power CONTROL BOARD" typically under the frig (above the defrost tray... It is, in fact, one of the EASIEST replacement parts to perform on the REFRIGERATORS...
of today.
On my refrigerator 22 year old AMANA (SBDE20S4SW which I love) that part has become quite rare (just because of time... but there are repair services that can refurbish OLD packs (10 days end to end & $100 - $200 later)... I fund one on eBay ... $195.
TURNED OFF THE BREAKER...
CIRCUIT BOARD 12106802: Replacement fiasco:
- Wiggled out the defrost tray (took pictures with my camera)
- Unplugged the door (control panel) wires from front (took pictures with my camera)
- Took out the one ***** hold box up... and slid it (wires & all) out to work on.
- Removed one top ***** & removed box cover (a lot of wires = lots more USABLE pictures!!)
- Changed the board... (TURNED CIRCUIT BREAKER ON) worked fine...!!
- Found my bad solder joint repaired/replaced it ... (TURNED CIRCUIT BREAKER OFF/ON)
- Put old board back in...
(control lights flashing... refrigerator NOT working).
(BREAKER off)
- Took CLOSE look at pictures (found red/white transformer CONNECTORs EXACTLY WRONG... (fixed)
(BREAKER ON)... Works great!
Have spare (12106802 PCB)... Plan on keeping it forever.
Story moral: $195 later (I didn't need to spend)...
Happy happy happy.
You can make yourself prouder.
PLEASE NOTE...
The "BREAKER" ... I never recommend touching ANY electronics without STATIC (ESD) protection.
A tiny (teeniest) static discharge around the MOST ROBUST electronics can destroy it... If the breaker is off... the refrigerator is still plugged in.. ergo FULLY GROUNDED... The likelihood of static discharge is quite remote... Just remember to ground your hand(s) to the refrigerator (always) before touching any electronics there-in.
Same reason all electronics are shipped in (silverized or PINK static) bags...
So get that MAKE & MODEL... check the sites below...
Any questions comment me back... I shall return
(my baby is having her 50th) needs sympathy too.
appliancepartspros... recommend... (also try, 3 estimates!)
SEARSPARTSDIRECT.COM
Partssselect.COM
repairclinic.COM
Easyapplianceparts.COM
Search Over 2 1 Million Appliance Parts
Water Filters Lawn Garden Appliance Parts
http://partssselect.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Find Your Appliance Parts
Mar 26, 2016 | Refrigerators
No power when television is turned on
1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
2) test the power cord for open or break
3) see for a blown fuse inside and replace, or c.breaker tripped reset.
4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
God bless you
Jul 31, 2012 | Zenith Televison & Video
Tv would come on and start blinking you had to beat on the back of tv just to make it stop blinking and now there is no blue screan think it took its last beating . wondering it can be fix or junk it
It can be fix.Maybe the problem is in the power supply or loose connection in the power section.Its needed to repair and troubleshoot by the authorized repair technician.
Jul 09, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a Jacuzzi circa 1998 model Z140 spa. The 50 amp gfi breaker is continually trippinhg. The electronic control box is a Balboa instruments MODEL, DU-H276-DCAH. A relay on the circuit board chatters...
Hello - sounds like you will need to replace the relay itself if possible, if not you most likely need to replace the circuit board considering its age.You can check by diconnecting the power to the board.
If you are not an electrition and you dont work with electrical STOP NOW!! and call electrition.
Following steps would be 1. Turn off breaker. 2.Disconnect wiring to the board. 3.Wire nutt off electrical to the board.
4. Turn breaker back on. If breaker does not trip , board will need repaired or replaced.
May 18, 2011 | Home
200 amp breaker is melting and power is flickering in house
Usually this is a defective breaker, possibly caused by water intrusion into the panel. This is NOT a do it yourselfer job -- refer this to a professional who knows what they're doing. The meter base needs to be pulled to cut the power to repair it and you are dealing with power that has virtually no fuse or breaker protecting it. If that sounds dangerous, there's a good reason -- it is. I get unnerved doing these. I hope I've helped you, though maybe not the answer you were hoping for.
Feb 14, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
Turned on and blue all over picture zenith b50m88w
sounds like you may need repair man. convfrgnce circuit problem.  intergrated circuit resistors. not easy repair.
Dec 08, 2008 | Zenith B50M88W 50" Rear Projection...
Electric baseboard heat stopped working
It sounds like your electric heater coils burned out. Contact your manufacturer on how to replace or repair them.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Heating & Cooling
Beats By Dr Dre Beatbox iPod Dock Logo
69 people viewed this question
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
