My samsung washer WA80U3 will not turn on - Washing Machines
Good day i have a samsung washer(toploader) model number: WA80u3. It does not go on at all
HI it may be that the fuse in the plug has gone, sometimes this can happen and its the last place you would look, sometimes the cable wire in the plug has come loose please only do this if you are Shure of what you are doing I hope this helps cheers eric
Nov 16, 2017 | Samsung Washing Machines
My samsung wasing mechine does not stop filling water. model wa80u3
it seems the washer's inlet solenoid isn't responding to the diagnostic computer on the washer and needs of replacement contact samsung to have it serviced
Feb 21, 2017 | Samsung Washing Machines
Samsung washer error code 8C
I show an EC code as a temperature sensor issue. Turn your washer off at the mains, wait 30 seconds, turn mains power back on and start a new programme. If that doesn't work, it's time for a service call.
I did not find anything for an 8C code.
Jan 26, 2017 | Samsung Washing Machines
Why won't my Samsung Front Load Washer Model # WA45H7000AW turn off automatically?
Samsung Top Load Washer WA45H7000AW/A2 ' Front ...
www.samsung.com > ... > Top Load Washers
Samsung Electronics Rating: 3.9 - ‎254 reviews - ‎$699.00
4.5 cu. ft. Capacity. Washer capacity has a direct impact on how much time you spend doing laundry. ... Top Load Washer with VRT (White) ... Owner's Manual.
Oct 16, 2015 | Samsung Washing Machines
My Samsung washer is throwing a code looks like a BE code how do I reset it. All I do is turn on the washer and in 20 second the code comes up with out touching anything
You can try plugging the washer from the outlet. Turn on the power knob on the washer for a couple seconds to release any stored power, then turn power knob off. Plug washer back in the wall outlet to see if this resets the code back to normal.
Apr 03, 2015 | Samsung Washing Machines
WHY DOES SAMSUNG WA80U3 WASH MACH NOT SPIN???
Could be:
1. No AC
2. Blown house or machine fuse.
3. Bad AC cord.
4. Bad on/off switch.
5. Bad Timer.
6.Broken Belt or Gear.
7. Bad Motor.
8. Clogged pump.
9. And more
If you can't find the problem Get professional service or replace it!
Jun 03, 2014 | Washing Machines
Samsung washer wont turn on
Unplug it for several minutes and then plug back in. This might reset it.
Apr 18, 2013 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung washer error code f1
What kind of detergent are you using? F1 in most cases means that the wrong type of detergent is being used. If it's a front-loader, you should be using h3 detergent.
May 21, 2012 | Samsung Clothes Washer Power Control Board...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
