Question about Pantone for fashion and home Color chooser 3.0 (FSX100) for PC, Mac
PANTONE (R) for fashion and home color chooser 3.0
What colors are they
The first # is hexadecimal. ff7188 Color Hex
Th3 9-3 might be a pantone reference http://rgb.to/rgb/9,3,38
Apr 14, 2015 | Tablets & eReaders
What color is pantone 7242
It's Pantone's propriatary color mix. It's doesn't really have a "Blue" or "Red" or "Yellow" name, just a hue.
May 23, 2014 | Adobe Photoshop 7.0 for PC
Hi, i'm trying the PMS code Pantone 2756 C on illustrator Cs4 and what i'm getting on the screen/printed material is completely different from the color bridge that i have
You cannot match a Pantone swatch book to your monitor unless you have calibrated it using something like Huey: http://www.pantone.com/pages/products/product.aspx?pid=562&ca=2 as a monitor is backlit and printed materials are not.
Depending on what sort of printer you are using, it also may need to be calibrated or have its profiles updated.
Oct 08, 2010 | Pantone Color Bridge Uncoated
How to get pantone into photoshop, i have photoshop c s 4 extended and a colorchoser 3.0 as a programme. how do i get this to work in photoshop ?
You can access Pantone colors thru the swatch pallet in photoshop.
They can also be access when you select the fill color by going to color/edit/content/fill and go to use/color.
Jan 28, 2010 | Pantone for fashion and home Color chooser...
I am the Graphic Artist and Printer for a public library. We have a logo that has the Pantone color PMS 375 green in it. I mix my own inks and have no problem reproducing the color properly on a printing...
Laser printers, although they have a larger color gamut than a CMYK offset press, still will not be able to reproduce a majority of Pantone special colors.
Professional inkjet printers, especially those using more than 4 inks, are far better at this - the ink pigments are more color-pure and concentrated than those in laser toners.
Remember, that Windows print drivers work in RGB, and use ICC profiles to convert color data to CMYK components for printer. If you have a CMYK file, and look at it on your monitor, it's converted (using monitor ICC profile) to monitor's RGB colorspace, and then back to CMYK with the printer ICC profile when printed. Converted twice with ICC, which always introduces distortions...
If you have a properly calibrated monitor, and a good printer profile installed, you have better chances of reproducing screen colors on the printer, especially if you work in RGB.
As a simple, but laborious solution, I would suggest preparing "swatch sheets" yourself using some graphics software. Preferrably in RGB, not CMYK. A series of gradients with the green component going from, say, half way to maximum, and other components in various combinations, like R0 B0, R10 B0, R20 B0,... then R0 B10, R10 B10, R20 B10... and so on. Print those, and try to find a spot in the gradients that is the closest to your color sample, and then make swatches with smaller increments around that color to find the best RGB combination.
Good luck :)
Nov 13, 2009 | HP Color LaserJet 5550hdn Printer
Color matching
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
May 20, 2009 | QuarkXPress
Emerald green
According to Pantone (the expert on color for industry): C=100 M=0 Y=70 K=0
Feb 07, 2008 | Pantone for fashion and home Color chooser...
PANTONE PRINTFIX SUITE - GPU12
That product is out of production, but its replacement is available. I believe you would find your best solution on the Pantone website or, next best, the website of the manufacturer of the Pantone Printfix Suite: Datacolor. I personally use Datacolor's Spyder2 and am very pleased with the results. My monitor represents true colors and has many optional viewing settings, which are invaluable.
Nov 23, 2007 | Pantone ColorVision Spyder2PRO Studio...
Pantone for fashion and home Color chooser 3.0 (FSX100) for PC, Mac Logo
113 people viewed this question
Top Pantone Computers & Internet Experts
David Payne
David Payne
Are you a Pantone Computer and Internet Expert? Answer questions, earn points and help others
