Question about managemylife.com
Kenmore Elite front-loading washer
Brand new Kenmore elite front-loading washer#796.4107. When washer is filling the water pressure is so strong it sounds like the water pipes are being pounded with a hammer while it determines how much water to use for size of load. Unacceptable noise. Had a repairman here yesterday and he said it is a problem with this LG washer. For the price this should be the best of the best. Any suggestions? I am going back to Sears store today to discuss further
  • 4 Answers
What the heck it this garbage about washers
Posted on Feb 12, 2014
3 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: sears kenmore washer front loading shows code F35.
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 08, 2011
  • 35708 Answers
SOURCE: Kenmore front loading washer leaves black marks over entire load of laundry
Odds are that if you have your Kenmore washer "looked at" the conclusion will be the same. As for the repair or replace issue, you will have to weigh the age of the machine, the cost of repairs already made or contemplated, and the cost of a replacement.
Posted on Nov 29, 2013
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front load washer is great but when it adds water, the water slams on and slams off. It does this multiple times per load. Our pipes are older and they bang with every load. Is it...
Check your water pressure at the sourse. Strong water pressure will cause banging noises from relay valves open and close. Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 24, 2010 | Kenmore 44102 Front Load Washer
Water seeps into my Kenmore Elite HE3 washer went is not in use. Does anyone else have this problem?
You are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. It's an easy fix, remove the top and the valve is right there, te part number i think is 8181694
Mar 18, 2009 | Kenmore Elite 45986 Front Load Washer
theres an error between the motor control board and the central control board,,meaning you might have lose connection,,or burnt,wire,,this i would let a technician look at,,,good luck
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
managemylife.com Logo
175 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
