Question about Symbol PDT 6846 Portable Terminal
Screen stuck on timeout on write - Symbol PDT 6846 Portable Terminal
My galaxy tab 3 never goes to sleep to a black screen. The wallpaper is always there. Is this normal
at the home screen, touch the app menu icon
choose settings
choose timeout
choose timeout value from the list (one minute timeout standard value)
touch the home icon button to return to the home screen
Mar 10, 2018 | Tablets & eReaders
How do you change screen timeout setting on ASUS tablet
Go to Settings -- Device -- Display -- Sleep and choose anywhere from 15 seconds through 30 minutes to Never timeout. Of course the longer the period, the sooner your battery runs down.
Aug 11, 2014 | ASUS Tablets & eReaders
Screen on my galaxy note 2 wont enter timeout
Go to "Settings >> Display >> Screen timeout" and adjust it to the value you want.
Sep 23, 2013 | Samsung Galaxy Note II LTE N7105 4G...
Application registry.wait for (0x7c802477365c3985) timeout
my blackberry appears in the following Applicationregistry.waitfor (0x7c802477365c3985) timeout
Jun 04, 2012 | RIM BlackBerry Curve 8520 Smartphone
Describe your AT&T BlackBerry Curve
BlackBerry smartphones support individual security passwords between four and 14 characters in length. The use of the password is designed to make sure that only the BlackBerry smartphone user can access the information stored on the BlackBerry smartphone.
The BlackBerry smartphone rejects less secure passwords, such as those composed of identical characters or those that consist of natural sequences (for example, 1234). In instances such as these, the BlackBerry smartphone will display the message The password cannot be a sequence.
Set a BlackBerry smartphone password
  1. From the Home screen of the BlackBerry smartphone, click Options.
  2. Click Security Options.
  3. Click General Settings. Note: If you are running BlackBerry® Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Change the Password field to Enabled.
  5. Display the menu and click Save.
  6. Type your new password and click Enter.
  7. Verify your new password by typing it again and click Enter.
Change the BlackBerry smartphone password
  3. Click General Settings. Note: If you are running BlackBerry Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Display the menu and click Change Password.
  5. Type your existing password and click Enter.
Turn on password protection using the Security Timeout feature Security Timeout is a feature that, after a predetermined amount of inactivity, will lock the BlackBerry smartphone automatically.
To turn on Security Timeout, complete the following steps:
  4. Set the Security Timeout field to the amount of inactive time the BlackBerry smartphone is permitted before it is locked automatically.
Note: Clicking Lock on the Home screen instantly locks the BlackBerry smartphone.
Unlock the BlackBerry smartphone
  1. Press any key on the BlackBerry smartphone to display the Enter Password screen.
  2. Type your BlackBerry smartphone password. Press Enter.
Important: If a password in incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
Additional Information When the Security Timeout feature is set for a longer duration than the Backlight Timeout feature, the BlackBerry smartphone will lock automatically when the combined duration of the features has elapsed. For example, if the Backlight Timeout feature is set to dim after two minutes and the Security Timeout feature is set for 20 minutes, the BlackBerry smartphone will not automatically lock until 22 minutes has elapsed.
Sep 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Windows XP Timeout
You can fix this by removing that software. But if you must keep it, you can change the timeout by doing the following:
  1. Login to Windows
  2. Start > right-click My Computer > Properties
  3. Advanced tab
  4. Under Startup and Recovery click Settings...
  5. You will find the timeout settings there
Best of luck. Please vote for this answer. Thank you.
Jun 19, 2009 | Computers & Internet
Return to home screen
Change the home screen timeout in Start->Settings-> D Home screen. Change the timeout there to a larger value. I use 15 min
Jul 29, 2008 | Motorola Mobility Moto Q
Screen light doesn't turn off
Check your display settings. Settings, Phone, Display: Check that Light Timeout is set (I have mine setup for 20 seconds). This should do the trick. If you wish to conserve yet more battery power, set "sleep mode" to on and set a power saver timeout (mine is set to 1 minute). good luck.
Jun 05, 2007 | Nokia E61 Smartphone
Symbol PDT 6846 Portable Terminal Logo
48 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
