Question about Konica Minolta bizhub Office Equipment & Supplies
Good Day. My Bizhub C252 reprints the previous prints i did together with the new pages i print. now the pages are just a mess with info printed on top of each other. What could be the problem?
  • Konica Minolta Master
  • 6,161 Answers
Clear the print jobs might have a corrupt file, clear all jobs in the print que and on the machine
Posted on Jan 19, 2016
Printerguy
  • 31 Answers
SOURCE: HP LaserJet 2420dn prints twice
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Posted on Aug 24, 2007
Kevin Hayes
  • 167 Answers
SOURCE: Problem Printing accurately colors from Corle Draw to Bizhub C252
The reddish greys are something a Fiery will correct, that is part of it's function. (GCR).
I would try turining colour management off, or rasterizing the file in Corel. I believe there is an option in the print window.
Have you tried making a PDF of the file and printing that?
Using the ICC profile could be a solution, but the Fiery is what is needed.
Posted on Feb 25, 2008
jtuminaro
  • 56 Answers
SOURCE: ghost printing
This machine needs a new fuser. That is a common issue.
Posted on Jan 15, 2009
leroyal
  • 2120 Answers
SOURCE: horizontal lines on printed page
You need a new Toner Cartridge
Posted on Feb 01, 2009
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Printing appears to reprint on other pages
I have seen several things fix a problems with reprint like yours depending on the spacing between the prints. There is a registration page in the service manual that points likely faults by the distance between reprints. This is based on the diameter of the failed part. Transfer roller, Print cartridge, and the fuser.
Apr 10, 2009 | HP LaserJet 2430tn Printer
Can't fold and staple multiple booklets
when you click on file then print in the window that pops up look at the lower right corner and you will see a box that says collate uncheck that box and it will staple correctly
Mar 05, 2009 | Konica Minolta Office Equipment & Supplies
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Greetins.
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
