Question about HTC FUZE Smartphone
I nid to reset my pasword...on the screen i can see a countdown time of 34 mins
How do I reset the countdown timer on a slazenger digital watch...please
Try Googling (Slazenger)(model)(manual) without parens to get instructions.
May 12, 2017 | Watches
User's guide for kambrook electronic timer kd94
Could not find a free guide, but e-how lists the basic instructions.
Instructions
    • 1 Set the day and time on the timer. Press and hold "Clock." While holding the "Clock" button, press "Day" to scroll through the days of the week and select the correct one. Press the "Hours" and "Min" buttons to select the correct time. Release "Clock" when you are finished.
    • 2 Press "Prog" set the "On" time for the switch. The word "On" and the number "1" will appear on the left side of the display.
    • 3 Press "Day" to choose an individual day or a block of days. Choosing an individual day means that this specific program will only activate on that day; choosing a block of days means that the program will be active on each day in the chosen block.
    • 4 Set the time that you want the timer to switch on by using the "Hours" and "Min" buttons to select the appropriate time. Press "Prog" when you are done to complete your entry of the "On" time.
    • 5 Select the "Off" time for your timer by using the "Day," "Hours" and "Min" buttons to choose when you want the timer to switch off. Press "Prog" again to save this entry. Repeat steps two through six to set additional timers.
    • 6 Press "Day" and "Hours" to activate the random timer mode. An "R" will appear on the LCD screen, indicating that the timer is in Random mode. This will cause your timer to switch on and off at different times, following no set pattern.
    • 7 Press the button that looks like a hand with the index finger extended to perform a manual override. The display will show you whether it is in Manual or Auto mode, and whether it is turned on or off. "Manual On" means that the time is switched permanently on while "Manual Off" indicates that the timer is turned off. "Auto Off" activates the program that you have set, while "Auto On" turns the time on until the next schedule "Off" time, after which it continues to follow your programmed times.
    • 8 Press "Clock" and "Prog" at the same time to use the countdown feature. Use the "Hours" and "Min" buttons to select the length of the countdown, and press "Manual" to start.
    • 9 To reset the entire unit and clear all programmed times, use the end of a paper clip or a ball-point pen to press the "Reset" button, located above the "Manual" button.
Read more : http://www.ehow.com/how_5565934_program-kambrook-timer-switch.html How to Program Kambrook Timer Switch eHow
Nov 24, 2011 | Hardware & Accessories
The load starts out with 1 hr 3 min on the timer, but during the process the timer may go from 35 min to 40 min, then when it gets down to 29 min it goes back to 34 min and so on and by the time its done...
not sure but sounds like a mother board is playing up, try turning it off at the wall over night just to see if it will reset itself.
if not you will need to keep asking.
Mar 25, 2011 | Washing Machines
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
How do I set the time on the 61048 SUNBEAM DIGITAL TIMER
This is a countdown-type timer, for precise cooking times, etc. Press hour and minute buttons to set time.
Press start button to begin countdown.
Press hour and minute buttons same time to reset timer.
Timer beeps each 5 and 10 minute intervals during countdown.
This timer does not connect to any electrical device, has a magnet on back, and has internal battery operated.
For large image of timer:
http://www.oneida.com/oneida-digital-clock-timer.html?utm_source=Shopping.com
Nov 06, 2010 | Sunbeam 6 Robinson Home Digital Timer
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Canon IR 3100 CN needs pasword
you need to clear thepassword in this order touch ADD FUNC key then the 2 and 8 keys together then touch ADD FUNC key again lcd screen should change touch copier then function then clear then pwd then ok then yellow reset 3 times that should do it
Aug 24, 2009 | Canon imageRUNNER C3200 Copier
HTC FUZE Smartphone Logo
16 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
