Question about Dell Computers & Internet
Dell pp41l Inspiron 1545-9068
I have had a Dell PP41L Inspiron 1545-9068 given to me. When I switch it on, within the space of a few seconds a blue stirated screen appears, the fan goes for about 5 seconds and if left, the laptop beeps twice, and that's it. Nothing else. I have checked the power supply by substation and same happens. I checked the memory in another machine and it works ok. I did wonder if it could be the DC Power Jack USB Ethernet VGA Video Board Can anyone suggest a possible repair please. Many thanks
  • James Grant
    James Grant Feb 13, 2014
    I have changed the hard drive, changed the battery, changed the memory, but nothing has changed. As soon as the power switch is pressed, within a couple of seconds the blue screen appears with stirations down middle, fan sounds for about 5 seconds and that's it. Laptop does nothing else except beeps twice (2 times). I was wondering if it could possibly be the VGA, USB power board that the power supply plugs into
  • 25 Answers
Try an external monitor.
Posted on May 05, 2014
3 Suggested Answers
ArmenianTech
  • 24 Answers
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Posted on Oct 08, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
HowcanI replace battery dell model PP41L
Remove battery and purchase a replacement online or Dell website.
There is usually a switch or slide that locks the battery in olace, move the switch/slide hold an remove battery.http://support.dell.com/support/edocs/systems/ins1545/en/SG/F123HA00MR.pdf
Nov 05, 2012 | Dell Inspiron 1545 Notebook
DELL 1545-1945 Motherboard needs replaced
Contact Dell directly, you might also want to check the price of a new computer, this may work out cheaper in the long run.
Oct 08, 2012 | Dell Computers & Internet
I need drivers laptop dell inspiron1545model pp41l win xp
Go to the link below and select : Inspiron 15 (1545) from the list. That will bring up all the drivers available for your computer. Just scroll down the page to see your drivers.
Link:
http://www.dell.com/support/drivers/us/en/usgen1/DriversHome/NeedProductSelection
May 28, 2012 | Dell Inspiron 15 Laptop
Dell inspiron 15 pp41l will not power on
Remove battery and clean contact points and reinstall the battery! if still does not work charge battery full and try again! If still does not work either battery is defective or power cord may not be good to charge the power!
Sep 23, 2011 | Dell Inspiron 1501 Notebook
All softwares for dell inspiron 1545 model pp41l
You can begin downloading your drivers for the inspiron 1545 by clicking here: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=INSPIRON1545
The only thing you need to do is select your operating system. (windows xp, vista, etc.)
Mar 07, 2011 | Computers & Internet
Wireless dirver dell model number pp41L inspiron 1545
you can find all drivers for dell inspiron 1545 here
http://www.general-search.com/download/video-dell-inspiron-1545-model-pp41l-driver-for-xp
Oct 05, 2010 | Computers & Internet
PP41L DELL LAPTOP SOUND DRIVER DOWNLOAD
Here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=
is a link to your drivers. you will need to select the correct operating system.
Jul 09, 2010 | Dell Computers & Internet
Hi i bought dell inspiron model pp41L it shutdown automatically what happend, any one can suggest me
Hi
Please update the latest model BIOS version on the system, if the problem persist after updating the BIOS check if the system is overheating if so call dell support number and inform the issue they will be able to replace the motherboard
Mar 31, 2010 | Dell Inspiron 1545 Notebook
Computers & Internet Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
