Question about Dake Johnson JH10W1 Horizontal Band Saws
Blade keeps popping off Model J-10 Dake Saw
Adjusted tracking but see no improvement
Can this saw be adjusted if it cuts out of square? And if so, how.
Hello, yes this saw can be adjusted.
To calibrate the table, use a framing square up against the rear fence and see how the blade tracks. To adjust this: loosen the bolts holding the rear fence down and move the fence until it is square with the blade track and tighten.
To adjust the bevel: use a speed square to check for 90deg and 45deg on the blade. Using the 13mm bolts found at the pivot point on the trunnion you can adjust the 90 and 45 degree angles.
Mar 12, 2016 | Hitachi 8.5"" Sliding Compound Miter Saw...
How do I get a manual for a trade master 9 bandsaw?
MODEL: 270S INSTRUCTION MANUAL - Industrial Tool ...
www.industrialtool.com.au/.../user_manuals/trademaster/RF270S.pdf
SHUT- OFF power and clean the BAND SAW and work area before leaving the machine. (11). ... Consult the owner's manual for recommended accessories.
Trademaster bandsaw manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesDake parma trademaster section i ii band saw instructions parts. Dake parmatrademaster, section i ii, band saw, instructions and. Vertical bandsaws ...
Trademaster RF 270S Instruction Manual - ManualsLib
www.manualslib.com > Brands > Trademaster Manuals > Saw > RF 270S
View and Download Trademaster RF 270S instruction manual online. METAL CUTTING BAND SAW MACHINE. RF 270S Saw pdf manual download.
[PDF]Trademaster Parts Manual - Utilimaster
Jan 21, 2016 | Blade Saws
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
Blade moves to the front and then pops off
1. Make sure you put the right tension. Check tension recommendations on your bandsaw/ manual.
Here's a good article about that. What is Bandsaw Blade Tensioning and Why is it Important
2. Adjust the blade tracking. I suggest you to read this blog for reference. Band Saw Tracking Procedures
Jul 01, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta 28-160 band saw 3 wheel, blade keeps coming off
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Nov 27, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Bandsaw blade keeps coming off Rexon BS 10
Unplug the saw and take the covers off the wheels. See if any of them show excessive end play or deflections when gently racking them from side to side. You may need to shim the wheels. Ideally, you want them all to track in the same plane, and you can check this with a straightedge.
There should be a tracking thumbscrew locked with a wing nut or some such on the back of the upper wheel. Put the blade on so it rides in the center of the tire, (move the guides out of the way if need be until you get the blade to track correctly), and turn the wheel by hand to see how the blade rides. That way you can make adjustments before it pops all the way off. By moving the bolt on the back of that upper wheel in or out you adjust the pitch of that wheel and change the way the blade tracks...
After you get the blade tracking smoothly under tension, you can move the guides back into position to support your blade during cuts.
Apr 10, 2009 | Saws
Dake Johnson JH10W1 Horizontal Band Saws Logo
Top Dake Saws Experts
Tom Chichester
ray gallant
Are you a Dake Saw Expert? Answer questions, earn points and help others
