Question about Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer
MFC -990 CW printer does not recognize a full yellow ink, despite it is original, cleaning run twice and other colours work fine
  • Brother Master
  • 783 Answers
Try rubbing alcohol on the outside of the head.
More often than not ink will dry from the outside in.
I've found that refill kits work once or twice, and then the cartridge is shot and i gotta buy a new one, but YMMV i guess.
Might just need to break down a buy another yellow cart.
Buyer beware, but you could break down and take a chance on this.
Edit:
If it's the pump, look in the documentation for a head clean or purge, this might help.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Posted on Feb 19, 2014
  • 9 Answers
SOURCE: Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Posted on Jun 05, 2009
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
alphacheese
  • 68 Answers
SOURCE: BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Posted on Jan 08, 2010
Jimsta01
  • 405 Answers
SOURCE: My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Posted on Mar 27, 2010
Have two Brother DCP-145C printers and use compatible inks. Now the yellow won't print in either machine. Despite trying cleaning cycles and replacing the yellow cartridges, the test print will not show...
100% you need to replace the print head,in the future use only original cartrige brother not refill or compatible cartridge.If you want to replace the print head you need to take care is difficult to change the print head,you must to unzip the all printer.If a have been useful please give me a vote.
Mar 22, 2011 | Brother DCP 130C All-In-One InkJet Printer
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 215C :yellow and red refuse to print
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 12, 2008 | Brother Multi-Function Center® MFC-215C...
Only print on black and yellow
did you use generic ink? those ink will clog the ph espacially the mag + yellow channels.
do use original brother ink carts because these contains special cleaning fluids!
Mar 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
Do you use generic ink carts?
Please insert an original brother BK cart. In case the printhead is OK the machine should work again. If there is still trouble the printhead might be clogged and cant be fixed anymore due to wrong chemical additives within the generic ink!
When inserted the original brother ink cart run the powerpurge:
press menue then start b/w (blue button) then foutimes arrow-up button. Machine is within the maintanance mode. press 7 then 6 then 3. Display shows PowerP_All. Press start b/w (blue button). Machine runs power cleaning. Press 9 then 9  to leave the maintanance mode. Print a test print sheet.
Oct 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Mfc 420cn
Do use original brother ink to fix the problem: Do the cleaning twice (All colors and bk). You should see some blocks of the missing colors. If not printhead is damaged and cant be repaired (Dryed out or damaged valve or clogged with particles). If machine displays unable to clean, search googl for ERROR 46 (Reset and change of waist inktank)
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
No Magenta and No yellow
If you have really already run the cleaning cycle more than 20 times you should have get an error 46 which means that the printer cant clean anymore! So if not, use original brother inkcarts and do the the cleaning twice. If there is no block on the testsheet, the printhead is crashed. You cant fix it anymore.
Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
