CAT Chennai cause list - Computers & Internet
P1884 code 2005suzuki forenza P0420 P0134 P0138
code p 420 refers to cat converter system , bank 1--efficiency below threshold ===causes ---cat converter faulty---wiring --heated oxygen sensor (HO2S), 2 faulty
code p 0134 refers to HO2S 1 bank 1-no activity detected ===causes --wiring open circuit -- heating inoperative --- HO2S
also refers to oxygen sensor ( O2S) 1 bank 1--no activity detected == causes wiring ---O2S
code p 0138 refers to HO2S 2 bank 1--high voltage === causes ---wiring short to positive ---HO2S--- ECM
also refers to O2S 2 bank 1 high voltage === wiring short to positive O2S -- ECM
I do not have a listing for code p 1338 but I suspect that it will refer to the other codes in some way
first fix is to check the cat converter is operational ( not cracked and blocking the exhaust system)
next replace the HO2S sensor ( one before the cat converter ) and then the O2 sensor (the one after the cat converter)
all the codes will relate to problems in that area
Sep 01, 2016 | 2005 Suzuki Forenza
Which is the best hearing aid centre in chennai?
The denoc is one of a best hearing aid centre in chennai.. They provide a best hearing aid to customers.
Hearing Aid Centre Hearing Clinic In Chennai
Jun 07, 2016 | Health & Beauty
Where i can find the best architects in chennai?
The studio7consultants is one of a best architects in chennai. They provide a best service to customers.
Architects in Chennai Studio 7 Consultants Chennai Archiects
Jun 07, 2016 | Generic USB cooling Pad w/ LED Lights for...
Which is the Best SEO Company in Chennai?
There are many seo companies in chennai, offering you great services, here in this guest posting there are top 10 seo companies which provides you high quality works as you expect. http://www.ihostingreviews.in/list-of-top-10-seo-companies-in-chennai
Apr 02, 2016 | Computers & Internet
P0136 sensor
this is the oxygen sensor behind the cat ,,,,, may be the sensor or a cat problem ,,,,, this sensor is monitoring the cat ,,,incorect readings will cause the code ,,,, may have a other problem causing code . ie fuel starvation or overfueling,,,,, mass air flow meter or temp sensor.... air leaks , need to look at data list to make sure other sensors are working correctly before changing the oxygen sensor
Nov 13, 2013 | 2001 Mercury Sable
Sony service centre in chennai
AUTHORISED SERVICE CENTRE
  • 509100_02021.gifMOUNT ELECTRONICSOLD NO: 30 NEW NO: 63 BIG STREET TRIPLICANE CHENNAI - 600005
    T:044- 28410965
  • 509100_02022.gifCLARITY SERVICENO - 16 MADURAI VEERAN STREET KALAIVANAR NAGAR PADI - CHENNAI
    T:044-26541166
  • 509100_02023.gifDIGITAL VISIONNO: 2 PRAKASAM STREET JANAKI NAGAR VALASARAAKKAM CHENNAI - 600087
    T:044-45550450
  • 509100_02024.gifCTECH ELECTRONICS36 MUTHUMARI AMMAN KOIL STREET THANTHAI PERIYAR NAGAR ON THARAMANI VELACHERY 200 FT ROAD THARAMANI CHENNAI - 600113
    T:22436343
  • 509100_02025.gifA.R.A.S. APPLIANCES PVT LTDRAINTREE PLACE NO: 9 MC NICHOLAS ROAD CHETPET CHENNAI - 600031
    T:64609144
  • 509100_02026.gifCHENNAI SERVICENO: 209 G S T ROAD CHROMPET CHENNAI - 600044
    T:64577688
  • 509100_02027.gifHIFI SOLUTION63 1ST MAIN ROAD GANDHINAGAR ADYAR CHENNAI - 600020
    T:43504713
    You may also CLICK HERE to open a link to find the service centers..
Feb 11, 2012 | Sony Cameras
Dodge dakota engine code p0420 is on whats the problem
Hello
There is not cut and dry answer for this code, here is a list of the possible reasons in order of how common they are.
Definition:
P0420 - Catalyst System Efficiency Below Threshold (in plain English this means the Catalytic Converter is likely worn out and not cleaning up the exhaust stream) A note about aftermarket Cats, they often don't measure up to the system parameters and trigger the same code again.
Here is the whole list of possibilities:
Possible causes - Three way catalyst converter Bank 1 most cars only have one catalyst monitor, it located after the main cat converter in the exhaust pipe, it looks like an O2 sensor but performs a different function.
- Exhaust pipe leaks up stream of the cat.
- Intake manifold vacuum leaks
- Fuel injectors may be faulty (to rich)
- Fuel injector leaks
- Spark plugs may be faulty
- Improper ignition timing
- Engine Control Module (ECM) (very unlikely)
Sep 28, 2011 | Cars & Trucks
K750i Body Panel get damaged & i want to buy the original one.
u can get it from anyone of this
ADYAR CHENNAI - INSIDE
12 2ND CROSS STREET KASTURIBA NAGAR ADYAR
CHENNAI
600020
Phone : 28292211
ASHOK NAGAR CHENNAI INSIDE
D-36 4TH AVENUE ASHOK NAGAR CHENNAI
600083
Phone : 28292211
AYANAVARAM CHENNAI - INSIDE
GROUND FLR CT.1 2 VARALAKSHMI VILL OLD NO 83/84
NEW NO 217/219 K.H. ROAD AYANAVARAM CHENNAI
600023
Phone : 28292211
Authorised Service Center
STEREOVISION AUDIO VIDEO PVT. LTD.
846 A MOUNT ROAD (NEXT TO INDIA SILK
HOUSE) CHENNAI
600002
Phone : (044) 28415944, 044-8535489
MADRAS AVS ELECTRONICS (P) LTD
609 MOUNT ROAD LAKSHMI BHAWAN GROUND FLOOR
(E BLOCK) CHENNAI
600006
Phone : (044) 28294576, 8292560
NO.108 KAMRAJ AVENUE IIND ST. ADAYAR CHENNAI
600006
Phone : (044) 24455940
Jun 15, 2009 | Cell Phones
What is the service shop telephone number for national make microwaqve ovens in Chennai, India
From this page:
Store Name Address Contact
TAMIL NADU
A.C.M ELECTRONICS 6/1 , SHOP NO : 1 , ANANDA GARDERN , BYEPASS RD , GANGAI NAGAR , VELACHERRY , CHENNAI - 42.
600042
City: CHENNAI
EXCEL ELECTRONIC INDUSTRIES 11-A , BIG STREET , KILPAUK GARDERN , CHENNAI - 600 010.
600010
City: CHENNAI
J.N & CO. 12 , BASEMENT , SAPTAGIRI COMPLEX , TTK ROAD , ALWARPET , CHENNAI - 18.
600006
City: CHENNAI Tel: 28265499 , 28271179
J.N & CO. A-7 , BASEMENT PARSN COMMERCIAL COMPLEX , 601 , MOUNT RD CHENNAI - 6.
600018
City: CHENNAI Tel: 24998199 , 24998399
M.S & CO 12 -B/17 , ELLAIMUTHU AMMAN KOIL STREET , VADAPALANI , CHENNAI - 26
600026
City: CHENNAI
R.N. ELECTRONICS 101 , A BLOCK , 3RD AVENUE , ANNA NAGAR , CHENNAI - 102.
600102
City: CHENNAI Tel: 42103987 , 26203569
RATHNA STORES 15 , RANGANATHAN STREET T- NAGAR CHENNAI -17
600017
City: CHENNAI Tel: 24342299 , 24311212 , 24311515
RATHNA STORES ( FIRM ) 43 , PONDY BAZZAR , T- NAGAR , CHENNAI -17
600017
City: CHENNAI
RATHNA STORES FIRM 199 , PURASAIWAKKAM MAIN ROAD CHENNAI- 600003
600003
City: CHENNAI
S.S ANNAMALAI SERVICE CENTER 123 , L. B. ROAD , THIRUVANMAYUR CHENNAI 41
600041
City: CHENNAI Tel: 24430257 24425059
SAMATH'S 95 , MOUNT ROAD , CHENNAI- 2
600002
City: CHENNAI
SAMRAT ENTERPRISES (P) LTD. 54 , LAKSHMI TAKIES ROAD , SHENOY NAGAR CHENNAI - 30
600010
City: CHENNAI
SANTHOSH SUPER STORES C-33 , 2ND AVENUE ANNA NAGAR CHENNAI 40
600040
City: CHENNAI
SHREE RAJ ELECTRONICS 3-A , ADAYAR BRIDGE ROAD , ADAYAR , CHENNAI - 20.
600020
City: CHENNAI Tel: 24917939 , 42054293
SRI LAKSHMI ENTER PRISES 9 , WAHAB COMPLEX CAMP ROAD , SELAIYUR CHENNAI 73
600073
City: CHENNAI
VICTORY ENTERPRISES 1 , EAST ROAD , WEST C.I.T NAGAR , NANDANAM , CHENNAI -35
600035
City: CHENNAI
VIVEKS LTD. 144 , ROYAPETTAH HIGH ROAD , MYLAPORE , CHENNAI - 4.
600007
City: CHENNAI
VIVEKS LTD. 167 , NORTH USMAN ROAD , T. NAGAR CHENNAI 17
600004
City: CHENNAI
VIVEKS LTD. 205 , PURASAIWAKKAM HIGH ROAD , CHENNAI 7
600007
City: CHENNAI
Jan 26, 2009 | Microwave Ovens
Digital camera service
i have sony cyber shot dsc w 5 model and its lens/shutter is not getting opened. please advise me how to get it repaired. pls reply to
afrijo@yahoo.co.in
Jan 09, 2008 | Cameras
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
