Question about Canon Pixma MP450 All-In-One InkJet Printer
Canon mx922 support code 6001 - Canon Pixma MP450 All-In-One InkJet Printer
Color photos are really off color.
Hi George!
Are using Genuine Canon Ink & Paper?
Here are some links to your printer troubleshooting videos etc.
Canon Support Drivers PIXMA MX922
Jun 30, 2015 | Canon Pixma MX922
How do I get a user Manual for Canon MX922
For some reason the list of MX printers is cut short in the 800's. Go instead to this web page: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx922#BrochuresAndManuals
. If this link doesn't work, I got to it by locating the Canon support page and searching for PIXMA MX922 (Search Canon is at the upper right). However you get to the MX922 page, scroll down to "Recommended Downloads" and choose either MAC or Windows Manual in PDF Format. Good luck.
Mar 01, 2015 | Canon Pixma MX922
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
I need the user manual for the Canon Pixma mx922
Here you go
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx922#BrochuresAndManuals
Jul 28, 2014 | Canon Pixma MX922
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
May 03, 2014 | Canon Pixma MX922
Canon Pixma MP450 All-In-One InkJet Printer Logo
658 people viewed this question
old marine
old marine
