Question about Hotpoint Washing Machines
Hotpoint wd645 trips rcd
Trips rcd after approx 10 mins. Heater element most likely?
barkencoa
  • 3463 Answers
SOURCE: Washer/drier tripping rcd!
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
Posted on Nov 27, 2008
SOURCE: hotpoint wd645 flashing f-08
The manual says F08 - Heater relay cannot be activated.The dryer might be having difficulty with this.It is not something that can be fixed.Heater Relay equipment might be damaged.Might have to call a repairman to set this right.Good luck.Do post comments for more help.
Posted on Jan 10, 2009
  • 100 Answers
SOURCE: Hotpoint WD860P trips rcd within second of being
the usual problem with tripping is the heater of the dryer box has become loose and touching an earth.
if you take the lid off you will see the box on top of the drum.
with the electric off you can look for loose/disconnected wires and wiggle the 2 metal tabs that are the ends of the heater, should not move.
you may be better with an engineer visit if it's not an obvious fault.
Posted on Feb 28, 2009
  • 323 Answers
SOURCE: I've had an issues on my Hotpoint WT761 Washing Machine tripping
take off the back and reset the overheat protection, it should be a little red button , maybe the unit was not reset when installed
Posted on Oct 03, 2009
beltronic205
  • 1461 Answers
SOURCE: wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Posted on Oct 07, 2009
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
My GS28v00GB001 upright freezer trips my RCD. I've replaced nearly every electrial component (capacitor) Starter device, Sensors and still it does it. Initially it runs for a number of hours till it trips,...
I am not familiar with Bosch but I do know that other brands use the defrost heater as a source for power to the compressor while running. If the heater is partially grounded it could cause this problem. If this is okay have your thought that maybe your RCD is going bad... just a thought
Apr 24, 2010 | Bosch Freezers
Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
Hotpoint reversomatic 9318-keeps tripping the rcd ring main breakers-why?
could be anything timer motor heater .. have you checked if bearings are gone ? most likely spider has collapsed and dropped drum onto heater and cut through it
Jun 26, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint WD860P trips rcd within second of being switched on
Feb 25, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Dec 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Hi.
Nov 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
15 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
