Question about Nissan Vehicle Parts & Accessories
Tappet clearance intake exhaust valve
Tappet clearence of nissan civilian bus
SOURCE: tappet/valve settings???
o.25mm when hot this is for inlet and outlet
Posted on Feb 11, 2009
  • 653 Answers
SOURCE: Engine tappet clearances
According to http://freespace.virgin.net/tommy.sandham/databook.htm# Rocker Adjustment, the cold clearance is .008" intake/.018" exhaust in the non-GT 1500cc, and .012" intake/.022 exhaust on the GT. Sweet little car!!!
Posted on Mar 01, 2009
SOURCE: VALVE CLEARANCE
I USE 0.04MM IN INTAKE AND 0.08MM IN EXHAUST VALVE
Posted on Apr 15, 2009
SOURCE: valve clearance 94 yzf 750
valve clearance for a 1994 yzf 750 is .11-.20 in. intake, and .21-.30 in. exhaust
Posted on Aug 26, 2009
wayneman01
  • 301 Answers
SOURCE: valve clearance on xr200 1993
.002" on the intake, and .003" on the exhaust valves (engine cold).
Posted on Nov 25, 2009
What is the tappet clearance for a 2.7 Diesel Nissan Hardboy 1999 model?
Try setting the valve clearance on your 1999 2.7 Nissan Hardboy diesel to 0.14 inches on the intake and exhaust sides.
Oct 07, 2014 | Cars & Trucks
Pls give me correct tappet valve clearance of intake and exhaust for 4G15 mitsubishi lancer
Valve clearance Intake 0.20 mm (Hot- at operating temp)
Valve clearance Exhaust 0.25 mm (Hot).
Feb 12, 2014 | 1986 Mitsubishi Lancer 1.8
Adjustment clearance valve rocker tappet
Pulsar 135 original tappet clearances
INTAKE VALVE 0.05 mm
EXHAUST Valve 0.10 mm
Get this valve adjustment done by the experienced mechanic with the help of Feeler Gauge
Aug 28, 2013 | 2010 Bajaj Pulsar 135 DTSi
1995 jeep 4.0 valve train clearance
As a rule of thumb most valve clearences are .010" inlet and.012" exhaust ( hot) but I suspect yous will have hydraulic tappets which take up the clearence as soon as the oil pressure comes up
Mar 09, 2013 | Cars & Trucks
What" the right clearance for td27 engine diesel
what are the valve clearences of a td 27 diesel engine
Feb 21, 2011 | 2007 Nissan Frontier SE Crew Cab
Valve clearence
Depends on many variables, such as, make, model, engine, type of transmission, year of manufacture, type of valve tappets or cam followers, (solid or Hydraulic). Solid lifters in an old hot rot Ford Depends on cam size. So a .010" intake clearance and .012" exhaust clearance is a good starting point for a 289 - 302 cid carb. engine. If you have a hyd. type of lifter, with engine running you loosen the rocker until it starts ticking and tighten it back down till it stops then 1/2 to 1 whole turn more. Repost with more info about your engine, car setup. Hope this Fixya up.
Nov 27, 2010 | Ford Econoline Cars & Trucks
Procedure of tappet adjustment
make sure engine is warmed up. Put cylinder one at top dead center,remove the valve cover,loosen all adjustment lock nuts,adust intake and exhaust valves on cyl #1 and intake valve on #2 and exhaust valve on #3. now rotate crankshaft 360 degrees clockwise, now adjust intake valves on cyl#3 and cyl #4 and exhaust valves on cyl #2 and cyl #4.now tighten lock nuts and install valve cover. specs are intake valves 25mm clearance and exhaust 28mm clearance, use a feeler gauge,heres a picture to show you where to check clearance.7675a52.gif
Mar 14, 2010 | 1986 Suzuki Samurai
WHAT IS THE TAPPET CLEARANCE FOR NISSAN GA 15 CARBURATED,INTAKE AND EXHAUST?
what is the tappet clearance setting for the ga15 nissan sunny
i need help to know the clearance of intake and the exhaust valve.
Nov 02, 2009 | Nissan Sentra Cars & Trucks
2001 yamaha warrior valve adjustment
hello
with the cylinder set at top dead center compression. using a feeler gauge between the tappets and the valves there should be .002-.003in clearance on the intake valves, and .006-.007in. clearance on the exhaust valves. thank you.
Mar 23, 2009 | 2003 Yamaha YZ 250
Valve clearances
On the intake 0.0008 or 0.0020 (it's in between these 2)
this is for the stem to guide clearance. (for the intake)
The Exhaust 0.0018 to 0.0030 stem to guide clearance.
Jul 10, 2008 | 1993 Nissan Pickup
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
