Question about Reebok Rt1000 Treadmill Walking Belt
How to replace irun drive belt? - Reebok Rt1000 Treadmill Walking Belt
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
What is the output voltage output to the rebook Irun 14301
Pull the belt with your feet while voltage applied to motor. A motor brush may be stuck
Jun 08, 2014 | Reebok Exercise & Fitness
Looking for a reebok irun adapter re- 14301
go to www.fitnessrepairparts.comand get itGod bless you
Mar 15, 2013 | Reebok Exercise & Fitness
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
Jul 03, 2012 | Reebok treadmill i-run s
After i run a mile or so the reebok irun will cutout how can i solve this problem
Dear Sir:
Please LUBE The lack of this produce enough friction between deck vs deck belt. this cause to shut down the machine.
After you lube RUN the software calibritation for diagnose and troubleshooting.
2) Test the main motor measure the input voltage.if there are the problem is the motor need repair.
3) Test the main board for output for input voltage motor, if there are Not the board is Faulty.
sincerely. God bless you
May 02, 2012 | Reebok Exercise & Fitness
Reebok irun belt not moving... Is there anyway I can test the motor to see if its that or the motor board that is not working?
Dear Sir:
Hello ? I hope everything is fine, I will try to help you.
Please see the videos with patience and carefully, you must need some basics tools: Screwdriver+Hexagonals+Dvom(Digital Voltemeter).
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=HmVt-SHSYAI&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=AFuRo2zHpCg&feature=related
With this videos you can fix it.
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 19, 2011 | Exercise & Fitness
Dc greenmaster gmd 82-05-2b how muchdoes it cost and where to buy? reebok irun treadmill motor does not work , need replacement
i want to purchase dc motor 3 hp continues duty 230 v dc power supply and 4800 rpm form my treadmil. please suggest. i am in chandigarh India.
Apr 25, 2011 | Reebok Exercise & Fitness
Replacing the tension belts on the reFord windstar 1998.
FOR COMPLETE Diagram Of this Procedure and Belt Routing Email Me@rejakwilsoon@aol.com and I will Send DETAILED PICTURE and Instructions
NOTE:
  • Minor cracks in the V-grooved portion of the serpentine drive belt are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
  • When installing drive belts on pulley, make sure that all V-grooves make proper contact with accessory pulleys.
Conditions requiring drive belt replacement are excessive wear, rib chunkout, severe glazing, frayed cords, etc. Replace any drive belt that exhibits any of these conditions.
REMOVAL
  1. Using a 15 mm socket or wrench attached on drive belt tensioner pulley bolt. Rotate drive belt tensioner clockwise to remove drive belt from pulleys. WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP.
INSTALLATION
  1. Install drive belt over all accessory pulleys (except drive belt tensioner).Rotate drive belt tensioner as described under Removal to install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys
Feb 10, 2009 | 1998 Ford Windstar
Reebok Rt1000 Treadmill Walking Belt Logo
22 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
