Question about Stoves EC500DOA Electric Kitchen Range
What is the oven capacity for ec500doa electric cooker
2 Suggested Answers
SOURCE: how do i swet the clock on my cooked - stoves ec500doa?
Hi
To set the clock you have to hold the 2 cook buttons in then use +/- buttons to set time. The cook buttons are the 2nd and 3rd buttons from the left next to alarm button. Hope this helps
Jasmin
Posted on Oct 08, 2009
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
When i using my oven, suddenly off i don't know how to fix
If there are no lights showing or electric fan or heat
Check the cooker trip / fuse on the main Fuseboard.
Should be 32 amp rating.
If Light works / or / and Fan but no heat then likely to be Cooker element. If its a double element or oven with grill you may still have reduced capacity to heat / cook food.
May 25, 2016 | Ovens
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
AER5630BAS died
Check the fuse/ circuit breaker in the fuse box first if that's ok some electric cookers have a fuse or a fusible link inside the back panel, you will need a multimeter to test it (be careful electric cookers are dangerous to work on) if you are not familiar with them.
Apr 21, 2014 | Amana AER5630BAS AER5630BAS 4.8 cu. ft....
Does a combination microwave use less electricity than a standard conventional fan oven?
A combo microwave would probably have at least 4 functions: simple microwave, a combination of microwave and convection, grill and convection. Convection is what your standard cooker already does. In fact, there isn't much point in buying a microwave oven that does any less. I have found that the microwave uses less electricity because it heats up more quickly and the capacity of the microwave oven is smaller.I have found microwave cooking much cheaper and faster. Oven mode is not the same as the microwave mode. microwave will take take 10 to 15 mins while the same thing will take 30 to 45 mins in oven. Here you will get more information about cheap electricity.
Dec 21, 2012 | Computers & Internet
How do i swet the clock on my cooked - stoves ec500doa?
Hi
Jasmin
Oct 07, 2009 | Stoves EC500DOA Electric Kitchen Range
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Stoves EC500DOA Electric Kitchen Range Logo
15 people viewed this question
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
