Question about Philips Senseo HD7832 Coffee Maker
My senseo turns off whenever i calc clean it - Philips Senseo HD7832 Coffee Maker
2 Suggested Answers
SOURCE: Senseo HD7832 Calc Cleanup
http://www.misc.philips.com/senseo-descaling/us/en/descalingHD7830HD7832HD7842.html
check this out. They have all the info you need to know. :)
Posted on Apr 07, 2010
I have a Braun Sensor model 3092 with two quirks. The machine brews coffee great, but I'm curious about 1) the strange, pitchy hum and 2) the Calc light stays on despite having cleaned it.
Yes I can under stand this you have done descaleing but you have not done descaleing in the proper way very thing has its sequence let take dolce gusto by pressing for few seconds the power button it will blink in green this means that the machine is now indescaleing mode when you're done you simply press the power of in this case you have told the machine that you want to do descaleing and after this the internal computer is reset to normal this is why you machine is still blinking because it had not been reset
Feb 24, 2016 | Braun Coffee Makers & Espresso Machines
Descaling problems
Don't run the clean operation. Just put white vinegar/ water, half and half and run as if making coffee. Let it cool and run through about 3 times and this will remove all scaling/buildup.The rune through plain water.
Nov 08, 2013 | Coffee Makers & Espresso Machines
Philips Senseo HD7810 /40 stops midway brewing
This lookes like a problem I experienced with another model of the Senseo. The problem here was the 470nF X-capacitor in the capacitive power supply. (230VAC models) Try replacing.
Aug 15, 2013 | Philips Senseo HD-7810 Coffee Maker
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
My Phillips Senseo only produces a small amount of water why?.
Hi Have you tried to clean and de-scale it, limescale can really play havoc with these sort of devices. If you still have the instruction book give it a read and follow instructions for de-scaleing. Also there is a cleaning cycle on some of the models which just flushes the senseo through to clear it out again it is in the book but if I remember rightly you fill up the resoviour then turn it on and put a large bowl under the spout and press both the one and two cup buttons at once. But I would do a descale phillips say it should be done about every 3 months this should also clean out any other muck that has built up, they also say to clean out the pod holder including the little hole. The Phillips website has help if you have lost the booklet.
May 22, 2012 | Philips Senseo HD-7810 Coffee Maker
I have cleaned my senseo , but the red light still is on. what do i do next?
Do not turn off the machine until all 4 cycles are complete (2 descaling & 2 rinsing ). The machine will then switch itself off. This is not properly explained in the instruction booklet.
Aug 25, 2011 | Philips Senseo HD-7810 Coffee Maker
Senseo won't turn on after running vinegar thru it to clean.
If it doesn't respond at all then make sure the plug is in the wall socket and the wire isn't damaged. If it's plugged in properly, the wire is intact and other electrical appliances work OK when plugged into that same wall socket, the macine will need some tender love and care from a mechanic.
May 14, 2010 | Philips Senseo HD-7810 Coffee Maker
How do you 'Calc Clean'?
Hello shid9
This is an easy fix. To decalcify your unit you need to make a water/vinegar solution. 2 parts water and 1 part vinegar. You might need to run two pots of the solution through if the first one is very cloudy. When done with that, rinse with 1 pot of fresh water. This should help remedy your calc problem. I hope this is helpful for you.
Happy brewing! NormanZ
Jul 15, 2009 | Philips Senseo HD7832 Coffee Maker
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
Philips Senseo HD7832 Coffee Maker Logo
29 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
