Question about Vehicle Parts & Accessories
Broken key in ignition vauxhall astra van 2000
How do i take the barrel out
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Assuming you can still turn the key, take off the shroud/casing around the barrel, turn to position 1 and there is a little hole in the metal surround, press in the hole with a point of small flat screwdriver and the barrel will come out. If you cant then its a bit more difficult and may result in a 2nd hand steering column
Posted on Feb 11, 2014
Vauxhall astra ignition
Suspect you have fitted the ignition switch back incorrectly and now the starter has been left switched in whilst engine was running.advise that you disconnect the battery and contact a qualified engineer.good luck
Apr 20, 2014 | Vauxhall Astra Cars & Trucks
Immobiliser faults
HI
I hope that you still have the old key.
all you have to do is that: open up the old key/remote and look inside it for a small black rectangle piece, this is the immobilizer chip.
remove it carefully don't brake it, and place it inside the new key/remote, put a little glue on it
good luck
Feb 24, 2014 | Cars & Trucks
Vauxhall astra circuit board
Many of these items may be controlled by a relay or circuit that is activated by the ignition switch. If the devices become active when jiggling the ignition switch (key), then you know that it is in the switch. It may still be in the switch, but the jiggling may not help. I have the same problem in my Dodge.
Apr 26, 2013 | Electrical Supplies
Central locking not working and key wont open doors
Is the battery dead by chance, sounds like that may be the problem here.
Nov 05, 2012 | Vauxhall Cars & Trucks
Vauxhall Astra 2002 3door front electric windows not working?fuse's fine.
Hi
I have a vauxhall astra 2002 1.6 sxi. Ive just put in a mirror switch as the last was broken when I purchased car. The switch has been tested and is working but the mirrors dont work? Cant find a fuse which is specifically for that. Can anybody help?
Thanks
David
Jul 28, 2012 | Vauxhall Astra Cars & Trucks
Where is the temperature gague sensor on a 2002 vauxhall astra envoy van?
The gauge sensor for your motor should be on the top of the fuel tank
May 15, 2012 | 1987 Vauxhall Astra
Remove ignition switch on zafira 2002
how do i change the ignition switch on my 2003 zafira
Apr 09, 2012 | Vauxhall Vectra Cars & Trucks
Vauxhall astra 2002 fusebox diagram
what number fuse lights the clock up on my 2002 astra van
Feb 08, 2012 | Vauxhall Astra Cars & Trucks
My car wont start, 1997 vauxhall astra 1.7 turbo diesel
This sounds like a problem in the fuel shut off circuit. When you turn the key on, it energizes the fuel shut off solenoid on the injection pump. When you turn off the key, power is removed and the pump is moved by spring to the fuel off position. Check for power at this terminal when you are having a problem, ( with the key on) If no power then I would check the wiring and connectors from this connection to the Ignition key. I believe it is wired direct. That can be checked at http://www.alldata.com/products/index.jsp
subscribe3 and get a wiring schematic for the car and see if it is wired direct to the ign switch of from a relay, I am sure it is a connection problem if you have no power.
A 1.7 diesel even if turboed, is dead slow in any vehicle let alone a van. Enjoy the fuel economy
good luck
Mar 11, 2009 | 1998 Isuzu Amigo
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
