Question about Yamaha Audio Players & Recorders
Locked wont turn on
Tone button stuck
    Genius:
  • Yamaha Master
  • 1,054 Answers
If one of the buttons is stuck in, it will make all the other buttons not work as they are all tied together. You need to take a small screwdriver or something to pop the stuck button back out.
Posted on Feb 11, 2014
Active x control
check all your fuses and fusable links, also check the body computor
Apr 12, 2014 | 1999 Plymouth Voyager
TURN OFF CAPS LOCK DELL SK-8185
Click on the Caps Lock button ;) if that wont work, then for lower case just use shift and the wanted letter
Aug 04, 2012 | Dell y530k - Slim Black Usb 104-key...
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Feb 07, 2012 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
To turn the tlk confirmation tone off... it does not work holding the - sign and turning it on now what?
Just read your message a second time. Is the sound following the release of the PTT button? If so, it is indeed the Roger Beep (aka talk confirmation tone). If holding in the minus button while turning the radio on does not turn it off, there might be something wrong with the radio, such as a one of the other buttons being slighty stuck. Or you have your keypad locked. To unlock the keypad hold the menu button in for 3 seconds until the lock icon disappears.
Another thing which will make a noise during or after transmitting is the low battery beep. You might check your batteries. Old, bad, poorly charged or defective batteries can cause this.
fyi: Some users might think the Call Tones are the Roger Beep.
Lastly, there is a PTT Timeout beep which will occur if you hold the PTT in for more than 60 sec while talking.
Hope one of these items is of help to you.
http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf
Best regards.
Oct 13, 2010 | Motorola Talkabout T6500 (7 Channels)...
Control lock stuck on (light on) and dryer wont turn on
TRY UNLOCKING IT? HOLD THE UNLOCK/LOCK BUTTON FOR THREE SECONDS TO UNLOCK OR LOCK THE CONTROL PANEL
Jan 16, 2010 | Whirlpool Dryers
Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Oct 27, 2008 | Toshiba Satellite A15-S157 Notebook
2002 oldmobile bravada ignition key is stuck in lock position
try and turn your steering wheel a little bit left or right and and the same time try and turn the key when it turns toward the dash then try and turn the key back. try and repeat this several times if neccessary. this should work. please rate this solution. thanks
Aug 30, 2008 | 2002 Oldsmobile Bravada
Ignition barrel
Tried turning the wheel a little to disengage the lock function?
Jul 07, 2008 | 1989 Nissan Pulsar
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
