Question about Maytag MDE2400A Electric Dryer
Drum roller support
My dryer is only 2 years old and after using it for about 15-20 minutes, it starts making a high pitch squeek.  I have looked inside and everything is very clean and belt looked in good shape but I noticed the square plastic part which I believe to be the drum roller support has been worn down due to rubbing with the metal part coming out of the drum. I believe I can fix this by replacing this part and by adding a bit of oil to the metal part coming in contact with the support. Does this make sense? Are there Maytag part stores in Ontario Canada or do other stores carry this part?
  • 290 Answers
You can try some very light oil on it to see if it helps. Also check the heating element housing and mounts. Sometimes you will get some sheetmetal squeeks as things heat up and cool down causing the sheetmetal to loosen and rub against each other.
I am sure you can get the parts locally, if not you can order them off the net or from Sears.
Post back to let me know what you find out.
Posted on Oct 27, 2007
  • Michael  Lindley
    Michael Lindley Oct 30, 2007
    Just wanting to follow up on your dryer and see if you got it fixed.
    Thanks/Mike
Squeek sound when first started cold
check drum,look like around , if look goo change roller
Nov 13, 2017 | Amana Dryers
Squeeking
Check the drum rollers for wear.
Nov 02, 2012 | Zanussi TC7102W Electric Dryer
We purchased a Roper washer and dryer in 1998, Its been the best, never a problem. However it has started making a high pitch squeek that has gotten really loud. The drum still turns Maybe somethings
YOU HAVE TO OIL THE ROLLER AND IDLER PULLY EVRY 5 YEARS IF YOU HAD NOT HAD IT DONE YOU MAIGTH HAVE RUING THE ROLERS LOOK FOR VIDEOS ON YOU TUBE HOW TO OPEN A WHIRPOOL DRYER SAME BRAND.
Feb 21, 2012 | Roper RGX5635E Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE2400A Electric Dryer Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
