Question about Revlon Hair 20 Roller Ionic Curlers Hot Hairsetter
My hot rollers suddenly won't get hot
The rollers were working fine and suddenly they will not get hot upon plugging in, after 30 minutes still cold
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
Suzuki 650 will not start when hot
Have you checked the CDI unit. These can breakdown when hot.
May 06, 2014 | Suzuki LS 650 Savage Motorcycles
My unit has been working fine now all of a sudden its not blowing cold air i changed the batteries and reset it i even opened it up and cleaned it with a soft paint brush what could it be?????? help it hot...
Shut the unit down of a hour or so . its over heated internaly i think because of the low voltage due to the heat wave let me know if it starts again. you might get by with 30 minutes
Jul 23, 2011 | Heating & Cooling
Engine stalls at 30mph upon hitting accellerator, then coasts to a stop. then won't restart. starter works, engine turns over, but won't fire up. next morning car starts fine. next week...
you may have to check the fuel pump function for pressure and volume when this happens as it could be a bad pump,you could have it checked when working as it could show up something but more likely should be done when it stops running.
May 19, 2011 | Ford Crown Victoria Cars & Trucks
It won`t start
make sure the air flow is ok, and the plug gap
Sep 16, 2009 | Garden
Hyundai Accent stalls and won't restart for 15 - 30 minutes.
check to see if you have fuel pressure after it dies. fuel pump could be getting hot and shutting off.
Jun 11, 2009 | 2002 Hyundai Accent
Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Jan 01, 2008 | Soleus MW-55
Revlon Hair 20 Roller Ionic Curlers Hot Hairsetter Logo
12 people viewed this question
Top Revlon Health & Beauty Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Revlon Health and Beauty Expert? Answer questions, earn points and help others
