Question about HP DesignJet 500 InkJet Printer
Scan axis Shutdown - HP DesignJet 500 InkJet Printer
  • Pete Fotheringham Feb 12, 2014
    Hi Don Prayitno, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    do you get a error code on screen?
    which exact model type do you have ( sticker on rear should begin with a Q or C)
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
I get error 0c00400000020c
System Error: 0C0040
Problem
Description:
Error in Printhead Drop Detection. This error code appears when the
Printer detects that the same area of nozzles do not work in different
Printheads. The possible causes are either fibres or a piece of paper
in the Drop Detector or that the Scan-Axis reference is incorrect.
Corrective Action: Try the following:
Manually recover the Printheads and check whether the error still appears.
If the error does appear again, then check that there no fibres or pieces of paper in the Drop Detector.
If the error does not appear again, then check that the Scan-Axis
stop of the Carriage is not deformed too much (some slight
deformation of upto 0.5mm is normal, but if it is bigger than that,
then replace the Carriage Assembly and recalibrate the Printer).
If the Scan-Axis is OK also, then replace the Drop Detector or the Service Station Assembly and recalibrate the Printer.
Found on the Service Manual
Aug 05, 2014 | HP Designjet 5500uv 60 IN Printer
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Possible paper jam.
3 Mechanical Initiator scan axis measure error.
4 Check that the Scan-Axis Motor is correctly connected.
5 Check that the Encoder Sensor is correctly connected.
6 Remove the Encoder Strip and clean it.
7 Perform the Scan Axis diagnostic test to troubleshoot the problem further
Jul 03, 2013 | HP Designjet T1100ps Printer
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Internal Error Shutdown carriage Axis Failure
hi my noverjet750 carriage axis failure error zaagad yahav ve!!!!!!!!!!!!!!
Aug 05, 2011 | Health & Beauty
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
Trying to find a schematic assistance to an error reported "system error 86:01" for my hp designjet 800.
System Error: 86:01
Problem
Description:
try the following:
utility (→ Page 4-26) and check the Scan-Axis usage. If the
Service Station/Aerosol Fan Assembly → Page 8-52.
 Perform the Carriage Movement test → Page 4-8. Okay this is the error code direct from the service manual. if lubricating the slider rod does not resolve this issue then you have other problems. more than likely the carriage belt is in need of replacement. check inside of printer for debris. check under the carriage assembly. see if you are able to move the carriage assembly smoothly from side to side. hope this helps.
Mar 12, 2009 | HP DesignJet 800 Printer
HP DesignJet 500 InkJet Printer Logo
Seeker5211
Seeker5211
