Epson XP-302 All in One
The scasnner refuses to recognise the PC Every thing else works OK. I have been looking at the Internet and there seems to be no such thing as an Epson Scanner that works. Why do they manufacture and sell such crappy products. NEVER BUY EPSON Harold geddis
  • polytek Feb 11, 2014
    Hi Harod Geddis, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    what os are you using ?
My printer doesn't recognise the new refill; and i can't seem to overide it to print. I tried a cheaper refill and then bought a genuine epson and it still doesn't recognise the replacement cartridge. ...
If this printer takes the Epson 69 cartridge you need to make sure the chip is replaced or reset on the refills you buy. I own a Cartridge World ink refilling store and I can't fill these cartridges yet because there are not replacement chips (that don't violate Epson patents) or a resetter for the chip. The chip communicates with the printer how much ink it thinks is left in the cartridge so you don't run it dry and ruin your printer. Once the chip says the cartridge is empty it will refuse to print until the chip is reset. It seems to me like you bought two refill sets from sellers that are scamming the consumer by not mentioning the chip problem. This is the main reason why I don't recommend internet refills is because it is really easy to take advantage of people. I would not buy refills until a reputable store like Cartridge World or Office Depot sells refills.
Jan 24, 2010 | Epson Stylus DX8400 All-In-One InkJet...
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Problems with ink catridge
is it an original?
try the old cartridge again and if it is ok get another cartridge
Jul 17, 2008 | Epson Printer
Umas Astra 5600 connection problem
what computer operating system are you?
Chances are this is a very old DOS scanners for Win 95/8- if your machine is XP/Vista it is not likely to work
Mar 18, 2008 | Office Equipment & Supplies
Printer says "Install ink cartridges correctly and then hit ok"
Try putting genuine ink it. If it still refuses to recognise the carts then it need to go back to Epson for a warranty repair. As an Epson eng 90% of the time, rubbish compatible cartridges are the source of such issues. They can even make the printer stop recognising genuine carts.
Do not mention to Epson that you used compatibles or they may refuse the warranty repair.
Oct 18, 2007 | Epson RX620 All-In-One InkJet Photo...
My book pro 500g external drive works on my xp home but not on xp pro
Hi Yodel, Plug in the Book Pro. Then ff you RIGHT mouse click on MYComputer then select PROPERTIES and then click on HARDWARE then DEVICE MANAGER Do you see any exclamation marks? If you do, click it with the mouse and select remove. Then unplug the Book Pro, restart the pc and then plug the bookpro back in. Let me know what happens.
Aug 20, 2007 | Microsoft Windows XP Professional With...
14 people viewed this question
jasbo
jasbo
