Question about PC Chips Computers & Internet
P13g front panel
My motherboard P13G, can't support DDR PC3200 ( 400 mhz ) how the problem ?
If i've got the right board, you have Nvidia chipset and graphics? I can't find, so far, what socket it is. What exactly is the problem with the card and I need to know what processor you're using because it makes a huge difference. Let me know through "add a comment".
Dave
Mar 28, 2011 | PC Chips P13G (V3.0) Motherboard
Tip
Toshiba 50HP95 Front Panel Lock Reset
Toshiba 50HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Can I take off the front panel of a Kenmore/Whirlpool washer to change the bellow?
Removing the boot will require that the front panel, door switch and console be removed.
To remove the front panel first remove the three screws securing the toe panel to the front of the washer and lift the toe panel up slightly pulling it forward.
Next remove the two screws securing the top front panel to the washer. The front panel can now be removed.
Jan 27, 2011 | Kenmore 44102 Front Load Washer
I am trying to get the front panel off so I can add a hard drive. I don't have a manual and I don't want to break anything.
Removing the front panel from a desktop computer to get access to the drive bays from the front is not too hard.
Front panels are usually attached to the case by one of two methods.
The plastic front panel can be held by spring loaded clips, you can see these clips if you look inside the case behind the front panel down each side of the front panel with two or three clips.
The other way of securing the front panel is by screws, the screws are accessed from inside the case behind the front panel, usually by 3 screws down each side of the front panel.
Nov 03, 2010 | Computers & Internet
Installed all the drivers for the pcchips site, but the box does not appear sound, how to solve this?
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 22, 2010 | PC Chips P13G (V3.0) Motherboard
Cant boot,with sound like ambulance :-)
First inspect the interior of the computer case while the system is running. A high pitch whine (ambulance sound) is often a cable getting in the way of one of the fans. Adjust accordingly if that is the case.
Second, is your computer starting/completing the POST self test? Do anything at all appear on the screen?
If not, try reseating CPU and then the RAM. Do each these steps one at a time. Sometimes that slip out of place because of the interior heat temperatures. Let me know if this helps or provide more info.
Mar 31, 2010 | PC Chips P13G (V3.0) Motherboard
No sound from onboard audio.
Good day sir/maam, check out first the system if there are installed onboard audio. In windows goto start, rigth click my computer, goto properties, hardware, device manager. Check the sound, video and game controller. If you dont see any question marks, check out your motherboards audio port, there are usually 3, green for the 2channel audio, blue for the line in/4channel audio and pink for the mic/6channel audio. You can use the blue one as long as you enable 4channel audio.
Oct 02, 2009 | PC Chips P13G (V3.0) Motherboard
Motherboard suppord CPU
google the mother board and then read the book for the board. it should list the compatable cpu's then you can log on to www.geeks.com and search for the cpu you want that will work with it.
Jun 27, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Feb 21, 2009 | 1996 Ford Thunderbird LX
Computers & Internet Logo
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
