Question about Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
The grinder in my Krups Espresseria EA8000 stops and whirrs. Then I take the coffee container off, clean the grinder out, and when empty, the grinder works fine. But as soon as I add coffee beans, it stops again and just whirrs. Any suggestions?
    New Friend:
  • 3 Answers
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Posted on Feb 28, 2014
4 Suggested Answers
SOURCE: Coffee Grinder on the EAM3500
We just went through the same situation. We opened the top the Magnifica to get to the grinder and removed the four screws to seperate the grinding pieces. Inside we discovered two black fosilized beans/stones! We removed those, cleaned out all the bean dust and it is working like new! Took about an hour.
Posted on Dec 28, 2008
SOURCE: grinder does not work!
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Posted on Apr 12, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
How do I dismatle the grinder on my Krups espresseria automatic
I suspect that as you have only managed to remove 2 screws from the beans container that this is going to be quite a task for you but here goes.
1) Remove the button from grinder adjustment by pulling or levering upwards
2) Lift beans container off
3) Remove front trim panel (square frame like a picture frame at front) Done by removing drip dray and thumping frame upwards with heel of your hand.
4) Undo 2 outer screws at top front of top housing
5) Undo screw in middle at back under where beans container was
6) Lift off top housing, you may need to rock & flex it a bit to release rear clips
7) Put knob back in & turn grinder adjustment fully right (clockwise)
8) You now need to mark that part of the grinder top that goes between knob and grinder so that you will be able to put it on exactly as it is now. Then remove that part from the top of the grinder
9) Now you can turn the top of the grinder anti clockwise further than the adjustment knob was moving it.
10) Once you have turned it as far as it will go you will be able to lift (with wriggling) the top part of the grinder out.
11) Cleaning out will be done with a small screwdriver and vacuum cleaner with nosey parker attachment fitted.
Dec 29, 2014 | Krups Coffee Makers & Espresso Machines
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
What do I do when coffee beans not getting to grinder
They cannot "not get to" the grinder, the hopper is mounted directly above the grinding teeth. The grinder is probably blocked and you will need to remover the housings and take out the grinder for cleaning and inspection. Most common cause of grinder blockage is dampness inside the housings from a leak somewhere inside the machine.
Jul 21, 2014 | Krups EA8250001 Espresseria Full Automatic...
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
Krups GVX2-12 grinder - ground coffee and container full of static so coffee sticks all over, including inside the container. Any ideas?
Most plastic products contain enough carbon black to neutralise this problem. Obviously not with yours.
Try a camera accessory cleaning cloth - specifically anti-static.
http://www.amazon.co.uk/gp/product/B00006IVV8?ie=UTF8&tag=shopwiki-uk-21&linkCode=as2&camp=1634&creative=6738
Cleaning less often will also help, and maybe a quick brush out would result in less mess.
Natural fibres like cotton cloths or bristle brushes will also help.
Coffee naturally has oils that, if left on, will eliminate this problem anyway.
Feb 07, 2010 | Krups GVX2-12 Electric Burr Grinder
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
624 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
