Question about Kodak ZD710 Digital Camera
New battery but still wont swith on
Not sure how to charge either
    Top Expert:
  • Kodak Master
  • 6,702 Answers
Be aware the Kodak Lithium CRV3 battery can't be recharged. Even if you have a charger where the battery can be connected to, it is dangerous to do so. It is an non rechargeable battery, and putting a current through the battery can overheat the battery and it even can explode. You never can get any electrical charge in that battery.
But your camera can be used with rechargeable AA NiMH batteries.
You need two and they can be chafed on most commercial (cheap) battery chargers. I do advice to buy a good brand of batteries, because even the better ones will only set you back 15 or 20 dollar. Sometimes you even can buy a set of 4 batteries, with charges (I advice the set) for little more.
When having a set of 4, still try to keep 2 sets of 2 batteries, that you always use together. On set in the camera one as spare.
When you do have new batteries, and the camera still won't switch on, carefully check is all contacts in then camera are clean and shiny. New batteries should have shiny contacts.
Contact can be cleaned with a dry cloth. Never use any sharp tool in or close to a camera. Scratches on a contact will cause oxidation and the camera will be damaged in a short time.
Success
Posted on Feb 11, 2014
What else could I check.
not sure but check to see if there is a white porcelain resistor mounted on firewall if its gone datsuns wont start with spark or fuel ok
Sep 06, 2014 | Charging & Starting Systems for Datsun...
My Syma 107 will not lift off the ground. It lifts a little bit and thats it. Its only a week old.
r u charging from the controller? if so put luthium aa batterys in controller the ones you have in there now may not be giving a full charge, you r turning the controller on when charging heli right? wait for the chareer light to turn back to green from red will tell u charge is done. u must have a computer 2 have posted this so charge ur heli from computer wait 4 it 2 light up red (the usb plug) b sure heli is off when charging the little swith should b forward toward nose of heli if it still wont lift off after a good charge b sure the top part of the blades are tight on shaft, its the two screws just under the top blades 1 of the 2 must b tight on the shaft or it wont get enough power if it is slipping, if it still wont lift off u may have a bad li po battery never run it way down!! always stop flying when u c the heli start to not have enough power to hover, always stop and let batt cool dn then charge, then after charge try 2 wait 4 a little bit b 4 flying 2 let batt cool from charging, i know it is very hard 2 wait, hoppfully u have not fryed the battery if u still cant get it e mail me and i will help u get up and flying good luck the s 107 is my main bird i work on them 4 friends all the time if i had it 2 look @ u would b fly n n 5 mintues my e mail is pznuraz@yahoo.com
Jul 29, 2011 | SYMA Toys industrial New Syma S107 Mini...
I changed the motor and now it wont start, it wont turn over at all, it wont crank, the starter wont turn over
Check all wiring. wiring to starter from switch, check if nuetral safety swith is connected. be sure wiring harness at the switch is ok. is battery charged?
Jan 10, 2011 | 2000 Volkswagen Jetta TDI
Nokia 1100 phone when i connect the charger only i can swith on my phone other wise i cant swith on the phone
The problem with your phone is battery, the battery on your phone can no longer hold charges, that is why it switches on when you connect the charger.
I would advice you get a new battery on your phone and make sure you charge the new battery for at least 4-5 hours before you start using it. doing this will solve the problem on your phone and charging the battery before usage will help preserve the life span of the battery.
Take care.
Jul 06, 2010 | Cell Phones
Starter wont crank new battery lights come on bright not even a clicking noise
not sure year you have but, the ignition swith under the dash usually dies on these.
Mar 13, 2010 | Ford Contour Cars & Trucks
My compaq presario c300 wont start up, power button illuminates the cooling fan kicks in then all the lights flicker and it the swithes off,
This is exactly the same problem as I have. I have changed the power brick and the battery but the problem still exists. PC World were useless and said it "probably needed a new motherboard" although I doubt this is the issue. It worked when I first put the new battery in, until the initial charge ran out. Did you find a solution?
Mar 04, 2010 | HP 435768-001 - Compaq Presario C300...
My wii fit board wont swith on- just flashes and turns off. new batteries have been fitted and the problem is still there
i had the same prob make sure the game using the board is switched on and then hold the button in
Jan 15, 2010 | Video Game Consoles & Games
Toshisba laptop wont swith on tried swithing a charger and battery still no change nothing happens
If you have tried a new charging cable and a new battery that kind of narrows it down to the power button being faulty.
Aug 30, 2009 | Toshiba Satellite Pro L300 Notebook
My laptop wont charge of swith on toshiba laptop brand new
If you have another power charger try it. It can only be one of two things. Bad charger or bad battery. Most likely the battery will need replaced
Aug 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Brand new battery wont hold a charge overnight
There has got to be a draw somewhere. Check the domelights, sometimes the lights burns out on and that will continue to draw. Also check you break lights sometimes the swith hangs up and keeps them on. sorry not more specific but youdefinitely have a draw somewhere
Aug 09, 2009 | 1992 Oldsmobile Bravada
Kodak ZD710 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
