Question about Garmin nuvi 205 GPS Receiver
Garmin 2720 touch the (s) and the (T) responds
  • Garmin Master
  • 2,130 Answers
You need to recalibrate the touchscreen. Try this: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Go through the entire procedure of pressing each dot as it appears on the screen.
Once completed the Nuvi will display Calibration Complete This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Posted on Feb 22, 2014
5 Suggested Answers
  • 7 Answers
SOURCE: touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Posted on Jan 24, 2009
SOURCE: Garmin 2720 lost sound
do not buy any this product garmin does not warranty or stand by its products, if have this fixed it will cost 300 but if you buy a new gps it will cost 150.00 can you understand this ?
Posted on May 23, 2009
  • 1738 Answers
SOURCE: Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Posted on Dec 25, 2009
Ironfist109
  • 3018 Answers
SOURCE: Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Posted on Mar 07, 2011
I have a garmin street pilot 2720 I bought a garmin nuMaps lifetime product to up date, would like to up date for the 2nd time can't find where to go about this, I have the product key and the...
Log into your account at www.garmin.com by using the myGarmin link.
With the unit connected to the computer go to the myDashboard link.
Your Street Pilot 2720 should show up on the dashboard.
From there you should be able to apply the update.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin StreetPilot 2720 GPS Receiver
My audio stopped working on my Garmin 2720
try depleting the battery until empty. that worked for my nuvi 760.
May 23, 2009 | Bennett Marine BENNETT DVD GARMIN...
May 09, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 touchscreen won't work, must use remote control.
I'll start with a comment I made on another post:
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. Actually the real last resort is to have Garmin fix it for a flat $250. Good luck.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
When type a S on my Garmin 2720 Get a T
try recalibrating your touch screen. I had to do this on an old 2610
Aug 06, 2008 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720
Is the power connector on the unit fully seated?
Dec 18, 2007 | Garmin StreetPilot 2720 GPS Receiver
Touch screen failed after I added external antenna
have you tried resetting it (press and hold find, the press power)
Dec 04, 2007 | Garmin StreetPilot 2720 GPS Receiver
Touch screen won't calibrate on garmin 2720 gps
Sep 30, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
48 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
