Question about Dryers
Beko DRVS 62 W Tumble Dryer Squeakig
Ok so my tumble dryer works but once it gets hot after say 10 minutes it starts making a loud metal squeaking noise. If I open it up and move the drum slowly I can hear the noise but can't work out what is making it do it. Strangely it doesn't always make the noise even when it's been going for 30 mins and hot either but more often then not it does. It also does not make the noise if I let it cool down and start it up again. Any ideas?
    New Friend:
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Posted on Feb 11, 2014
Testimonial: "Thanks for the reply. Will take it apart and investigate."
SparkGap
  • 363 Answers
SOURCE: LG tumble dryer
This could be a worn out or loose belt. You can get to it through an access panel on the back of the machine. Just make sure the power is disconnected first! Hopefully a replacement belt will be easy to obtain in your area. Regards
Posted on Sep 24, 2007
  • 56 Answers
SOURCE: My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Posted on Mar 20, 2008
SOURCE: Beko tumble dryer not drying.
is there a reset button on a beko tumble dryer drvs 62 w pls
Posted on May 14, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
jan mczeal
  • 632 Answers
SOURCE: My tumble dryer squeaks really loudly when its
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Posted on Oct 27, 2009
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
    DRYER MAKES NOISES.
    A loose or worn BELT can make funny noises
    Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
    The glides on drum worn and making metal to metal contact.
    The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
    CHECK FOR LOOSE BELLOES inside the drum
    Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
    The blower:
    Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
    The bearings:
    The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
    The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
    The drum rollers or castors:
    It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
    Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
    GOD IS GOOD !!!!
    May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
    New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
    check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
    Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
    Indesit idv65 tumble dryer squeaking really loud
    hi check drum bearing to see if worn
    Jan 21, 2014 | Dryers
    Beko tumble dryer
    your thermostat is faulty.
    When your back panel is off, you'll see an air duct going vertically. it will have a dollar size little switch on it.
    replace it with a new one.
    Dec 16, 2017 | Dryers
    DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF WARRANTY.
    Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
    Also could be a faulty motor..
    Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
    Motors will sometimes get a dead zone in them and this help move it from the dead zone.
    Sep 26, 2009 | Dryers
    Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
    go into service mode and reset
    to do this move to delicates turn on dryer and keep
    pressed down cancel button for about ten seconds release
    then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
    it is now reset, this worked for min a drcs68w
    Apr 23, 2008 | Dryers
    Dryers Logo
    266 people viewed this question
    Top Dryers Experts
